Author Topic: 1986 K10 axles  (Read 7201 times)
Offline Proplant
1986 K10 axles
« on: August 24, 2017, 10:42:38 pm »
What are some direct bolt on axles to upgrade from a 10 bolt rear end on these trucks?
Thanks
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 1986 K10 axles
« Reply #1 on: August 25, 2017, 05:37:57 am »
14 bolt from a 3/4 ton, 1-ton would need spring pads moved. The 3/4-ton 14 bolt came with either a semi-float (same as 10 bolt) or full float.
 1986 Chevy K30(under repair)
Offline blazer74
1986 K10 axles
« Reply #2 on: August 25, 2017, 02:46:05 pm »
73-87 3/4 ton 14 bolt 10.5 ring gear full float or 9.5 ring gear semi float will bolt in and with a conversion ujoint.
Also thru 91 with a suburban 3/4 ton .
They both will be 8 lug.
The semi float can be converted to 6 lug with 88 and up 4x4 semi float axle shafts and spacing out the brakes.
88 and up axles will have a different spring perch spacing for the exception of the 3/4 ton suburban thru 91.
88 and up semi float axles can be either 6 or 8 lugs and come in 2 different widths, 4x2 65" wms or 68" wms approx.
again have diff spring perch spacing than the 73-87.
« Last Edit: August 25, 2017, 02:53:42 pm by blazer74 »
Offline Proplant
Re: 1986 K10 axles
« Reply #3 on: August 25, 2017, 05:40:06 pm »
Thanks for the help
