Author Topic: Window roller replacement  (Read 4230 times)
Offline Harmon
« on: September 13, 2017, 10:06:15 am »
I need to replace a roller on my 86 chevy truck passenger window (power window).  It is no longer moving, and i see you can order one that comes with a rivet.  I do not have the tool to properly squeeze the rivet and am wondering if there is a differnty way?
Thanks
Re: Window roller replacement
« Reply #1 on: September 13, 2017, 10:40:35 am »
If the roller isn't broken or flat on one side from wear due to insufficient lubrication, don't bother replacing it.  Most window rollers do not actually roll, they slide.  Thoroughly lubricate the tracks in which the rollers "slide" and it will function as if it were new.  Use a medium density lithium grease, such as white Lubriplate (GM #1052196) or similar.
Watch out for razor sharp edges and don't operate the power window while your hands are inside the door!
