Author Topic: torque converter bolts  (Read 15637 times)
Offline chevn-up
« on: September 25, 2017, 03:45:48 am »
hey folks, trying to remove the torque converter from the flex-plate. This is an 85 TH350. My question is are these bolts reverse thread? I haven't been able to bust 'em loose yet.
Re: torque converter bolts
« Reply #1 on: September 25, 2017, 06:22:15 am »
Lefty loosey righty tighty
Put a little more effort into and they will loosen just make sure you are using a six point so you don't round them off.
Offline chevn-up
« Reply #2 on: September 25, 2017, 05:44:46 pm »
Thanx VileZ. I am soak'n them in liquid wrench, and will try again. Appreciate the 6-point idea.
Offline chevn-up
« Reply #3 on: September 25, 2017, 07:54:15 pm »
a small pic.
Offline josh0325
« Reply #4 on: September 25, 2017, 08:12:11 pm »
I've always used a flywheel wrench to hold the flywheel, while I break them loose
Sent from my XT1585 using Tapatalk
Online bd
« Reply #5 on: September 25, 2017, 08:28:51 pm »
Use a flywheel spanner (image) to hold the flexplate from turning while you loosen and subsequently tighten the converter bolts.
Offline chevn-up
« Reply #6 on: October 19, 2017, 08:09:38 pm »
Ok, almost re-assembly time. Been researching the net for bolt torque specs. I think I have the numbers...... flexplate to crankshaft, 60-65 ft lbs. torque converter to flexplate, 35-45 ft lbs. and the transmission to the engine block, 25 ft lbs. Are these numbers ok?
Online bd
« Reply #7 on: October 19, 2017, 08:32:19 pm »
Offline chevn-up
« Reply #8 on: October 20, 2017, 03:51:26 am »
Thanks bd, mucho better to have the exact #'s rather than ball-park figures. Oh yea, good eye on the pic. It is a 350c.
