Changing trans fluid:
Topic: Changing trans fluid: (Read 2987 times)
Stewart G Griffin
September 28, 2017, 11:04:03 am »
TH-350C
In changing the transmission fluid:
a) What solvent should i use to clean the inside of the pan?
b) What's the best type of pan gasket to use? Cork? Rubber? etc?
c) Best brands of filter, fluid, gaskets etc?
Re: Changing trans fluid:
September 28, 2017, 06:52:14 pm »
Best style here:
https://www.summitracing.com/parts/lub-llt-g350?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-lubelocker&gclid=EAIaIQobChMI8eDkuojJ1gIVB5F-Ch2oIAI7EAQYASABEgKzjPD_BwE
but you can use either as long as the pan is not warped, the mating surfaces are clean, just start all of the bolts before you tighten them and do not over torque them.
Wipe it clean with a rag and then rinse with brake clean or water and soap. Dry it and reinstall.
