Author Topic: Restoration update ( grandpa's truck)  (Read 7099 times)
Offline dr.ifixit
« on: October 10, 2017, 09:07:22 am »
I just wanted to show off my work so far, if finished the engine with rebuilt and repainted everything ( upper half only )  and I started on the rust repair . I've got new floors, inner and outer rockers , cab corners , lower fender corners and inner and outer door skins. Almost time to start melting some metal.
Sent from my XT1609 using Tapatalk
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Restoration update ( grandpa's truck)
« Reply #1 on: October 10, 2017, 09:29:05 am »
Looking good. Hang the doors and use sheet screws to make sure everything lines up right before welding. Hate to see you do all this work and have the rocker too high or something.
 1986 Chevy K30(under repair)
Offline dr.ifixit
« Reply #2 on: October 10, 2017, 12:50:40 pm »
Good point I would have just welded it all in and tried to put the doors back on later. Thank you
« Reply #3 on: October 10, 2017, 06:18:49 pm »
Definitely do not do that! The door needs to be properly fit before you weld anything.
Offline dr.ifixit
« Reply #4 on: October 11, 2017, 08:40:02 am »
I've replaced quarter panels on cars before but this is my first rocker panel replace , glad I posted and you guys replied before I started burning it in. I'm going to end up replacing the floors and kick panels too since there's not enough left to weld to
