Technical Forum (Read Only)
Chassis Electrical and Ignition
(Moderators:
bd
Basics: The Importance of Vehicle Ground
Topic: Basics: The Importance of Vehicle Ground (Read 73860 times)
bd
October 14, 2017, 08:59:53 pm »
VEHICLE GROUND
by bd
GROUNDWORK
An electric power source enables various wiring, connections, electrical controls, and components, collectively referred to as a circuit, to achieve a purpose. Without power, a circuit is merely a vacant
"potential"
pathway that promises appliance operation without actually delivering it. Consequently, a power source is fundamental to circuit operation, and good connections are crucial. This is obvious. There is no revelation in this — until we look closer. Electric circuits consume energy. Every electrical component, whether an appliance, switch, or interconnecting wire, consumes voltage in proportion to the resistance the component presents to the current flowing through it. This occurs because every known conductor possesses an inherent resistance to current flow, however slight. As voltage and current power an electric appliance,
100% of the voltage applied across the appliance is consumed
in forcing current to flow through the resistance, thereby represented, in accordance with Ohm's Law (see Appendix). The current is neither depleted, converted, nor altered by the appliance but is limited in intensity by the resistance encountered and the voltage applied. Ohm's Law applies to every component in the circuit, such that
100% of the voltage applied across the circuit is divided proportionally between each component comprising the circuit, according to its resistance
In practice, for wires properly matched in gauge to the current they must conduct, the maximum allowable voltage consumed by the wiring is limited by design to a nominal amount (typically <3% total, or <0.4 volt maximum in a 14-volt circuit). Generally, operating voltage losses are much lower because continuous-duty circuits are rarely operated at maximum capacity. Thus, the voltage loss (aka, drop) across the wiring of a properly constructed circuit, under normal circumstances, can be considered negligible (<<3%).
In application, a power source and its connected components create an uninterrupted current pathway that loops
from
the power source
through
a designated appliance
back to
the power source. "Ground" is that specific section of the circuit that
returns
current to the power source
directly from
the last designated appliance in the circuit without experiencing an appreciable voltage loss, typically <<1.5%. Why <<1.5% instead of <<3%? Often taken for granted, 'ground' is roughly
one-half
of every electrical circuit. It is one-half of the framework around which everything electrical is constructed, tying the various pieces together to achieve a functioning system. One-half of 3% is 1.5%. Therefore, the voltage loss across just the ground path can be crudely approximated as <<1.5% of 14 volts, or <<0.2 volt,
assuming the ground path is an electrical wire or cable.
BUT (…there is always a caveat…), if the ground path is the steel body or frame of the vehicle and all connections to the body, frame, and battery are clean, tight, and fully serviceable, then voltage loss across that ground path will be so low as to be virtually unmeasurable. Can you suggest a reason why?
Hint
: It involves the effective relative cross-sections of the conductors. The effective cross-sections of the body and frame are huge compared to the cross-section of a wire or cable. Even though steel has ~7–12 times (depending on the alloy and temperature) greater electrical resistivity than copper, there is so much steel that its greater resistivity is inconsequential.
THE CRITICAL ROLE OF GROUND
"Ground" is the baseline within any given electrical system on which every electrical component relies to function correctly.
For electrical systems in general, as the power source return path, 'ground' is defined as the system-wide reference of zero potential, zero voltage, and zero electrical energy. Essentially, it is the controlled, hence predictable, divergence of voltage away from zero (ground) that makes electricity useful. All meaningful comparisons of electrical energy and work within a circuit depend on ground. Circuit voltages are specified and measured relative to ground; thus, voltage is either positive, zero, or negative relative to ground (that is, above, equal to, or below
zero
electrical potential).
To ensure proper circuit function, ground connections and throughput must be
perfect
! There is no room for error, especially if circuit complexity increases and multiple circuits share a common ground path. Any error occurring in the ground baseline will broadly compromise the electrical functions of all circuits sharing that ground — more on this in the subsequent section.
Virtually all vehicles manufactured since the mid–1960’s use negative-polarity ground systems. As a result, measured voltages are generally zero or positive relative to ground. Bear in mind, however, that from manufacturer to manufacturer, there are no assurances that the system ground is, in fact, the negative side of the power source. Therefore, when in question, it is prudent to verify ground polarity through direct observation and measurement.
Contemporary automotive electrical systems employ a simple, single ground reference. Within specific contexts, ground is also referred to as chassis, common, or earth. On a broad scale, "ground" is considered fully comparable to the electric potential of the body and mass of planet Earth, universally defined as unvarying and zero. Traditionally, 'ground' is the power source (e.g., battery, generator, alternator) zero-voltage electrical terminal comprising the metallic frame and body (i.e., the chassis) that supports, surrounds, and shields the various components and circuitry of the vehicle's electrical system. Because the steel chassis generally extends throughout a vehicle, ground connections are readily available wherever needed, reducing the expense and complexity of routing redundant dedicated ground wiring. However, following the advent of vehicle computers, to help alleviate the development of ground errors that were frequently experienced in aging microprocessor-equipped vehicles, beginning in the early 1990's, General Motors' medium and heavy truck divisions abandoned using the metallic chassis and bodies of their vehicles as the universal ground path in favor of dedicated ground cabling that connected directly to the negative terminal of the battery. Thereafter, GM Truck considered appliances to be properly grounded
only
if and when they were effectively connected directly into the network of ground cabling.
HIDDEN INFLUENCES OF "FLOATING" GROUNDS
Consistently flawless and uniform ground connections are crucial to the proper function of
every
electrical system; imperfect grounds are a nemesis. Occasionally, electrical systems suffer from unwanted multiple ground levels that are not uniformly zero. For example, the ground bus for a sub-circuit or network of sub-circuits can serve as a "proxy" or "false" ground if it is
above
below
, rather than equal to, the primary system ground due to electrical isolation from the ground reference terminal of the power source (which is true zero). Such isolation results when a poor intermediate connection exists in the ground bus
somewhere
between
the sub-circuit(s) and the ground terminal of the power source. Non-zero ground levels are said to "float" above or below ground.
'Floating grounds' are universally undesirable!
Electrically energized components connected to a 'floating ground bus' may seek alternate return paths to B- through the non-energized components that are paired with (share) the 'proxy' ground. In other words, circuits back-feed. The resulting symptoms are senseless, unpredictable, and often quite wild!
Floating grounds can result from errors in (re)assembly or develop over time due to loose, broken, burned, oxidized, or painted connections within the ground path. They typically produce bizarre symptoms that can be difficult to rationalize and diagnose. Under the right circumstances, floating grounds test the patience of even the most seasoned electricians. Weird, inexplicable combinations of dim lights, wacky gauge readings when electrical appliances are switched ON, totally inoperative electrical equipment, and electrical appliances that
randomly operate when switched OFF
are telltale signs of floating grounds. One light dims as another brightens; relays randomly buzz and click; the dash lights illuminate when the wipers are switched ON, yet the wipers don't work; turn signals illuminate dimly but don't flash; dash lights dim when a door opens — the irrational combinations of symptoms are endless. In cases where the engine ground connection to B- is poor, unpredictable alternate ground paths may occur through drivetrain components such as the transmission, universal joints, and drive axle bearings, or transmission cooler steel lines — even through liquid engine coolant — resulting in electrolysis and destructive erosion of bearing surfaces and metal castings. The aluminum components utilized in many engine cooling systems are particularly susceptible to electrolysis induced by floating grounds.
Resolving floating ground problems becomes easier with experience and familiarity with factory ground locations. Don't be fooled by the unpredictable randomness of seemingly "supernatural" symptoms. It's pretty much nuts and bolts. Patience and time are key. Ultimately, solving floating ground issues is routine and methodical:
study the relevant schematic diagrams that map the affected appliance wiring, then systematically identify and trace the offending ground path(s) on the vehicle to locate and repair breaks and poor connections. Add supplemental grounds if needed.
SERVICING THE GROUND PATH
Never take an electrical system ground connection or pathway for granted! The importance of good ground connections
cannot
be overstated!
Impaired ground paths cause a myriad of bizarre symptoms when quasi-energized circuits haphazardly function due to unpredicted, substitute ground paths. Faulty grounds can be responsible for mysterious engine shut-downs and random “Check Engine” light activity on computer-controlled engines, or the random illumination of instrument cluster turn and high beam indicators when the horn button is pressed. Perhaps the wipers stop working whenever the HVAC high-blower is ON. Such bizarre and intermittent symptoms always suggest a poor ground … not as an assurance, but statistically!
General service considerations
Star washers promote corrosion between a ground surface and its attached terminals by allowing moisture, dust, and corrosive salts easy ingress to the connection while reducing the effective contact area. Hence, star washers should be avoided at any connection carrying ≥3 amperes. Specific connections to exclude star washers are the blower motor ground, alternator ground, engine block ground, engine-to-cab ground, frame rail grounds, radiator support grounds, and starter motor connections. Star washers should be removed and discarded, and then the connecting surfaces cleaned, burnished, and coated with an antioxidant compound as specific problems are identified and remedied.
Except for the starter motor, a steel or brass flat washer may be used between bolt heads and ring terminals. The outside diameter (OD) of the flat washer should be the same as or slightly larger than the OD of the terminal(s). Split lock washers are allowable between bolt heads and flat washers. Ideally, starter motors should use a cadmium-plated shoulder nut (aka flange nut or frame nut) to securely fasten the battery cable ring terminal to the large stud of the solenoid without lock washers. However, substituting a cadmium-plated steel hex nut and a Belleville washer should serve nearly as well.
For general-purpose soldering of electrical splices and terminals, use 0.028" – 0.040" diameter 60/40 (Sn/Pb), 63/37 (Sn/Pb), or 70/30 (Sn/Pb) ROSIN CORE SOLDERS, ONLY. To resolder rigid printed circuit board foils and through-hole component solder joints that have sheared from standing wave vibrations, substitute 3% – 7% silver-bearing (Sn/Pb/Ag or Sn/Ag) rosin core solder to take advantage of its increased shear strength. See
Basic Skills: Soldering
if you desire more information.
To effectively insulate and seal bare wire-to-terminal and splice connections, use dual-wall, adhesive-lined, polyolefin heat shrink tubing (aka marine-grade heat shrink). Be sure to slip the tube, cut to the proper length, over the wire
before
attaching the terminal! Shrink the tube evenly using a heat gun (the safest method), a micro-torch adjusted to a low temperature reducing/carburizing (yellow) flame, a match, a lighter, or a similar heat source.
WORK SAFELY!
If using an open flame, be very careful of flammable vapors and materials that are in proximity to your workspace! Move the flame continuously to prevent scorching of the shrink tube or wire insulation. Allow to cool for at least three minutes before handling.
Replace Scotch-Loks
with properly prepped, crimped, soldered, and shrink-sealed splices (image), or substitute suitable modular terminals that are housed in OEM-style molded connectors. The ID of ring terminals should closely match the OD of studs and screws. Replace damaged, deformed, or improperly sized ring terminals with uninsulated (bare), heavy-duty, electroplated (tinned), solid copper or brass, brazed or open-barrel terminals.
Loosely preinstall
marine-grade heat shrink over the wire, cut sufficiently long to fully encase the terminal barrel and overlap the wire insulation by ~1/2". Strip, burnish as needed, firmly crimp, and solder the stranded wire to the bare terminal. Once the solder has cooled, reposition and set the shrink tube using moderate heat. Inspect ring terminals for excess insulation or adhesive covering the ring contact surfaces and trim as needed.
Always place the ring terminal carrying the greatest current closest to the ground source (generally located at the base of the junction). If all circuits support roughly equivalent current loads, place the ring terminal with the largest outside diameter (the greatest surface area) closest to the ground source. Ground contact surfaces should be clean, bare, shiny metal. Ground connections between dissimilar metals or those exposed to weather and/or corrosive environments should be liberally coated with a high-quality antioxidant compound, such as Truck-Lite NYK-77, Gardner Bender Ox-Gard, or thick white lithium grease to help reject moisture and salt, and retard electrolysis and corrosion.
If a ground bus becomes overburdened by current, the only solution is to augment the ground path with additional or upgraded cabling and connections. In some cases, this means increasing cable size. In other cases, it may mean reorganizing the sequence of ring terminals within a given stack and/or dividing the stack into multiple ground attachment points. Still, other cases may require reforming or replacing terminals to correct terminal distortion or improper sizing. For example, the
maximum
combined
voltage drop
allowable across an alternator charge lead and the ground bus is 0.5 volt when the current output from the alternator is at maximum. If an upgraded alternator with increased current output capacity is installed on a vehicle, both the alternator charge lead
and
the alternator ground lead, if used, may require replacement with larger gauge cabling to carry the additional current. Otherwise, the alternator’s regulated voltage may be partially consumed by the undersized cabling, and the batteries will charge no better than before the upgrade.
Another example: the individual connections and wiring within a ground system may be "independently and separately" perfect. Yet, when the individual ground wires are assembled into a "stack of ring terminals" under a bolt or screw, current flow becomes opposed by cumulative resistance if the effective cross-sectional area anywhere within the stack or between the stack and the point of connection to the ground bus (e.g., the chassis) is deficient. The result is a 'floating ground' with a portion of the system voltage wasted across the shared attachment point and any alternate ground path(s) that may occur. One possible solution is to redistribute the individual wires amongst multiple ground attachment points while ensuring that the rings are properly sized to carry the current and fit the screw diameters, ordered with the smallest ring at the top and the largest ring at the base of the stack, and undistorted to maximize contact between adjacent rings. For instance, the 4-amp instrument lamps and a 15-amp control solenoid for aftermarket airbags share a ground attachment point to the cabin sheet metal. Every time the bags are charged or emptied, the instrument lamps glow dimly. The cause: a deficient connection, creating a 'floating ground' that backfeeds the instrument lamps. How? The ground attachment is overloaded due to poorly stacked and incompatible ring terminals. The solenoid ring terminal has a 1/4" ID; the dash lamp ring is sized to a #8 screw; the large diameter heavy-duty ring for the solenoid is stacked on top of the smaller diameter ring for the dash lamps; a factory star washer resides between the small ring terminal and the cabin sheet metal. A simple solution may be to ground the instrument lamps and airbag solenoid separately, burnish both ground attachment points to bare, shiny steel, then assemble using two suitably sized screws, no star washers, and liberal coatings of antioxidant compound.
Essentially, as the current load on a system or sub-system increases beyond its original design capacity, such as by upgrading or adding appliances that increase current demand, or by stacking too many ground wires onto a single attachment point, or by feeding too many subordinate grounds into an undersized and overloaded common bus, the links of the supporting system made inadequate as a consequence must be upgraded concomitantly to compensate for the increased demand.
continued below...
Last Edit: June 19, 2026, 12:02:04 pm by bd
bd
October 09, 2018, 07:02:33 pm »
Specific service considerations
Thoroughly burnish and clean the battery cable connections!
Employ a specially configured battery terminal brush (image) to service conventional battery connections, removing any paint or corrosive salt encrustations. Severe encrustations may need to be chipped or scraped away. Inspect for sloppy workmanship leaving a bulbous (i.e., lumpy) accumulation of solder coating the contact surfaces of battery cable ends. File, scrape, sand, or buff away excess solder to ensure smooth, uniform, and conforming connections. Avoid dispensing acid neutralizers directly to or around the battery. Acid neutralizers consist of highly reactive chemical bases that interact with battery acid to produce salt residues nearly as conductive and damaging as the battery electrolyte. Instead, use clear water and a nylon-bristle brush to rinse away accumulated dirt and conductive corrosive films. Be sure battery caps are fully installed before and throughout the battery cleaning process! Thoroughly rinse all adjacent and surrounding surfaces until completely cleaned of chemical splash. Metallic paints are particularly susceptible to discoloration and etching if acid sits on the painted surfaces for too long. Allow the battery and terminal ends time to dry or, while wearing suitable face and eye protection, carefully blow them dry using low-pressure compressed air. Liberally coat the dry battery posts, pads, and terminal ends with thick lithium grease (arguably the most economical and effective choice), antioxidant compound (pricier but similarly effective), or battery protector aerosol (the most expensive and least effective choice — think of it as liquid money in a spray can — wrapping a battery terminal in a $10 bill won't protect it from corrosion), then reattach the cables to the battery and tighten the terminal bolts to the specified torque, typically 5 – 6 lb-ft (60 – 72 lb-in) for lead posts and pads.
Inspect for star washers, loose connections, and corrosion wherever battery cables are fastened to a battery disconnect switch, relay, junction block, or the starter. Check for large diameter star washers at the engine block ground stud or bolt. Discard any star washer(s) encountered, then thoroughly clean, burnish, assemble, and coat the connections with a good antioxidant paste.
Check the tightness and integrity of all connections to the cab ground points on both sides of the firewall. Remove any star washers discovered and service the connections as required, coating them with a high-quality antioxidant paste.
Mitigating destructive electrolysis
Although electrolysis is not generally an issue with 1973 – 1987 (1991) light-duty GM trucks as delivered from the factory, subsequent replacement of factory components with aluminum manifolds, water pumps, radiators, etc., can introduce potential for severe electrolytic etching, structural erosion, and coolant leaks. Electrolysis is an electrochemical process in which direct current (DC) passes between dissimilar solid metal electrodes (e.g., iron and aluminum) through an intermediate, conductive electrolyte solution (e.g., aqueous engine coolant), causing the dissolution (i.e., dissolving) of at least one of the metal electrodes (e.g., the aluminum) into an ionic state, freeing the metal ions to pervade the electrolyte solution, gradually decreasing the pH of the solution while increasing solution conductivity, thereby increasing electrolysis, and so on. Electrolysis is exacerbated when the engine coolant becomes acidic (pH <7), either because of an exceptionally low coolant-to-water ratio or because the acid inhibitors in the coolant have been depleted due to inadequate maintenance. Once established, electrolysis becomes a relentless, self-perpetuating mechanism. Fortunately, solid iron and aluminum are better conductors than coolant, such that electric current preferentially flows through the solid metal (the intended ground path) rather than the coolant. But, if the metallic ground path becomes corrupted, degraded, or interrupted due to poor, misplaced, or insufficient connections, current can continue to flow to B-,
using an alternate ground path through the coolant
, creating the perfect environment for destructive electrolysis.
Checking for poor grounds that lead to electrolysis is a simple process of measuring voltage between the engine coolant and B-. While the engine is cool, connect the negative (black) lead of a digital voltmeter (DVM) directly to the clean negative terminal of the vehicle battery. Select the DC Volts 2-volt scale. Carefully remove the radiator cap and immerse the clean metal tip of the DVM positive (red) probe directly into the radiator coolant without contacting the radiator neck or other metal parts.
With the engine running and all accessories switched ON, if the meter displays >0.10 volt, excessive current is flowing through the coolant, indicating one or more deficient electrical system grounds. Although the shared cabin-to-engine, engine-to-B-, and frame-to-B- ground paths are the most impactful to overall electrical system health and the prevention of electrolysis, individual accessory grounds must not be overlooked. Have an assistant switch the accessories and finally the engine OFF sequentially every few seconds while you monitor the voltmeter. When the voltage suddenly decreases, you have discovered the offending circuit. Then, with all accessories switched ON and the engine running, check for any voltage drops between engine-to-B- and frame-to-B-. Ideally, all readings should be <<0.10 volt. Finally, disconnect the ground cable from the battery and measure the voltage between the radiator coolant and the battery ground cable. This will reveal whether the cooling system is actually generating voltage and current flow through a galvanic reaction similar to a battery. Galvanic reactions are also corrosive, but are generally controlled by the chemical inhibitors added to engine antifreeze/coolant.
When measurements >0.10 volt indicate compromised grounds, the offending circuit paths and connections must be precisely located, thoroughly serviced, and restored to full function. In rare cases, grounds may require rerouting to more appropriate connection points, improved connection methods, or the addition of supplemental grounds. Experimentation may be necessary, along with significant time investment. In addition, scheduled periodic flushing and maintenance of the cooling system using a fresh 50/50 mixture of distilled water and low-silicate engine coolant containing an appropriate suite of chemical inhibitors will help control electrolysis and galvanic corrosion. Don't be discouraged. Persistence will pay off.
STANDARD INVENTORY OF 1973 - 1987 (91) C/K/R/V LIGHT-DUTY TRUCK GROUNDS
Reiterating, the purpose of the primary ground bus is to ensure that vehicle ground is “zero” everywhere. To that end, all subordinate ground buses that feed into the primary ground bus must be at the same ‘zero’ potential. If the ground reference is not consistently zero throughout the vehicle, matching exactly the potential at the battery ground post, all manner of ill will can result. You'll believe the vehicle is haunted!
Good grounds are vital!
Voltage drops across circuit ground paths while the circuits are operating should measure virtually zero. This is true for all low- to medium-current ground wiring (<30 amps). Perform a comprehensive inspection of wire condition and wire-to-terminal connections. Oxidized or frayed wiring should be cut back, cleaned, re-terminated, and soldered - or entirely replaced, terminated, soldered, and shrink-sealed using marine-grade heat shrink as needed.
Whether you are experiencing electrical problems or refurbishing the vehicle, take an inventory of every vehicle ground connection and service each appropriately (disassemble and clean connections to shiny bare metal, then reassemble applying a liberal coat of moisture-rejecting antioxidant paste). Upon thorough inspection, you should discover and validate the following vehicle grounds (recommended wire sizes are listed for any ground paths that need to be fabricated and installed):
battery-to-engine block or alternator bracket (2 gauge)
this is the primary high-current ground path (>150 amperes) for the engine and cab, supporting the full burden of the starter cranking current, charging system current, and cabin electrical appliance current.
DO
NOT
attach the battery ground cable to an intake manifold bolt or stud! Manifold bolts tend to loosen gradually following repeated engine heat/cool cycles as manifold gaskets compress and lose elasticity.
battery-to-right (passenger side) frame rail (10 gauge)
this ground path is crucial as the primary extension of the main vehicle ground to the rear of the vehicle
battery-to-radiator support (10 gauge)
this is the primary ground path in support of all of the forward running lamps, forward turn signals, headlamps, and horn(s)
back of right cylinder head-to-cabin firewall (5/16" braided strap or 8 gauge)
this primary ground path ensures the cabin is adequately grounded to support all cabin-mounted interior and exterior electrical appliances.
DO
NOT
attach the cabin ground cable to a valve cover or intake manifold bolt or stud! Valve cover and intake manifold bolts tend to loosen gradually following repeated engine heat/cool cycles as gaskets compress and lose elasticity.
dash lighting and interior appliances-to-cabin left kick panel sheet metal (various, but typically 18 and 16 gauge)
this shared grounding point, common to nearly all of the electrical appliances inside the cab, interior lighting, and instrument panel, is crucial to preventing the occurrence of floating grounds and associated electrical ghosts.
rear lamps-to-bed (16 gauge)
ensures the rear lamps are suitably grounded; alternatively, ground the rear lamps directly to the right frame rail
bed-to-right frame rail (14 gauge)
ensures the bed is suitably grounded in support of the rear lamps and other appliances grounded to the bed
cabin firewall-to-engine compartment hood (1/4" braided strap preferred for superior flexibility, otherwise 12 gauge, suitably located with sufficient length to allow opening and closing of the hood without catching, excessive flexing or stretching of the wire)
(optional yet highly recommended) helps manage radio "bzzzzzzz" and provides a stable ground for an optional hood mounted engine compartment lamp
all-aluminum radiator-to-radiator support (5/16" tinned-copper braided strap)
to enjoy a suitable service life when replacing the factory original copper-brass radiator with an all-aluminum design, install a 5/16" tinned-copper braided strap between the replacement aluminum cooler and a well-grounded radiator support panel. Adding this supplemental ground will help mitigate electrolysis and subsequent perforation of the aluminum assembly.
WARNING
neglecting the installation of a supplemental ground can shorten the service life of an all-aluminum radiator to as few as ~12 months due to electrolysis.
Additional primary ground connections are okay. However, if any of the recommended ground connections are missing, fabricate and install them
post haste!
If damaged, repair, rebuild, or replace them!
continued below...
Last Edit: June 03, 2026, 03:19:20 pm by bd
bd
Re: Basics: The Importance of Vehicle Ground
May 31, 2026, 12:19:49 pm »
GLOSSARY OF SYMBOLS AND TERMS
— "greater than" math symbol used to compare relative values. The arrowhead
always
points to the lesser value:
a > b
, means value "
a
" is greater than value "
b
— "equal to or greater than" math symbol used to compare relative values. The arrowhead
always
a ≥ b
, means value "
a
" is equal to, or is greater than value "
b
— "less than" math symbol used to compare relative values. The arrowhead
always
a < b
, means value "
a
" is less than value "
b
and
— "much less than" math symbols used to compare relative values. Generally limited to three, the greater the number of arrowheads (
) in the series, the greater the separation between the compared values.
Ag
— chemical symbol for silver (from Latin: argentum)
B-
— effectively, the negative terminal of the battery or power source. In a negative-ground electrical system, B- is defined as possessing zero electrical energy.
"____" bus
(also,
buss
) — a primary current pathway or circuit channel emanating
from
(the power bus or supply bus) or
toward
(the ground bus or return bus) a power source and leading to or returning from a circuit, to which other conductors or circuit channels are connected and depend. The physical conductor, sometimes of a heavier gauge, that is common to and shared by the power source and one or more discrete circuits. A "bus" is a primary current path that serves as the link between a power source and its connected circuitry.
circuit
— the
complete
path
of an electric current. A circuit, to be complete, must connect to one terminal of a power source, run through a load, and return to the opposite terminal of the same power source in a continuous, uninterrupted, conductive loop.
common
— a current path or electrical connection that is shared by multiple circuits (e.g., common positive; common negative). Typically, however, by consensus and unless otherwise noted, "common" refers to the ground bus or the point of ground connection between an electrical device and its power source.
current
— the rate of non-random, coordinated migration or movement of individual electric charges. Expressed in amperes, current is the net electric charge per second flowing past a defined, stationary reference point. One ampere equals ~6.24 x 10
18
electric charges per second (one Coulomb per second) of current flow. Current flow is
forced
by potential differences, naturally flowing from regions of high electric charge (high potential) to regions of low electric charge (low potential) to establish a uniform charge across all regions. Current is
never
consumed
by a circuit or any of its components. Whatever quantity of charge leaves a power source to enter a circuit
must
simultaneously
exit that circuit and return to that same power source. That is to say, the current flowing into any circuit or component
precisely
equals
the current flowing through and out of that same circuit or component — current IN equals current OUT. Conversely, current OUT equals current IN.
DC
(also,
dc
) — direct current. Current that flows only in one direction through a circuit in accordance with the polarity of the applied voltage.
electric charge
— a quantifiable property of certain elementary atomic particles (i.e., electrons and protons) that causes them to exert forces on one another across a distance. By convention, electrons have a negative charge and protons have a positive charge. Electric charge is the collective or net effect of the negative and positive charges at a specified location. In practical application, electric charge is caused by the surplus (excess) or scarcity (absence) of electrons (e
) with respect to what is normal for a given substance.
electromotive force
(often abbreviated
emf
, or
EMF
, and occasionally
E
) — not a force, but an energy transfer represented by the potential difference, expressed in volts, between the opposing terminals of an electric power source that, when applied to a complete circuit, can cause current to flow.
floating ground
— an electrically isolated “ground” possessing a non-zero voltage relative to the general system ground (or zero voltage reference bus). Floating grounds generally result from poor electrical connections within the ground path and are universally undesirable.
ground (earth)
— systematically chosen for convenience, ground is the effective base or reference potential in an electric circuit to which all other potentials are measured or otherwise quantified and compared, and which is defined as and assumed to be zero. The zero reference terminal of a power source. The zero-voltage reference bus. Commonly, the terminal of the power source that is electrically connected to the conductive chassis, frame, housing, or case of a device. The current return-flow conductor or circuit channel, or system of conductors or circuit channels, that connects one or more loads to the zero reference terminal of the power source. All potential differences within a given circuit or interconnected network of circuits are quantified (measured) with respect to ground. Ground (earth) is considered to possess sufficient relative mass to sink or null (absorb and effectively disburse or dispense) any transient or spurious electric charge to zero.
HVAC
— Heating, Ventilation, Air-Conditioning system
load
— two distinct definitions within the context of electrical circuits:
1)
although it can be
any
component that consumes electrical power, "load" as an object typically refers to the specific appliance a circuit is designed to control. A load is labeled as such because of the demand it places upon the power source. In any given complete circuit, the resistance of the load is inversely proportional to the current flowing through that load: the less a load’s resistance, the greater its current demand. Conversely, the greater a load's resistance, the less its current demand. By design, the greatest resistance in any given complete circuit is the load.
2)
as a quantity, "load" is the amount of current burden that an appliance imposes on its power source. Current load is synonymous with current flow; the greater the (current) load, the greater the current flow. Thus, a
large load
implies
high current demand
; a
small load
implies
low current demand
. When "load" refers to an
object
, it generally refers to the specific appliance burdening the power source. When "load" refers to a
quantity
, it refers to the current demand placed on the power source by the appliance. Example: "The
load
[e.g., an LED fog lamp] imposed a 5-amp
load
[i.e., current demand] on the battery." The key to understanding and avoiding ambiguity is recognizing the context of usage and knowing the multiple meanings of ‘load.’
Pb
— chemical symbol for lead (from Latin: plumbum)
potential
— (aka, electric potential) expressed in volts, the work expended to accumulate and maintain an electric charge at a specified location
— the difference in potential, measured in volts, between two distinct and separate points
resistance
— expressed in ohms and dependent on the geometric length and cross-sectional area of a wire or cable, resistance is the opposition to simple direct current (DC) flow. Every conductor and electrical component possesses some amount of resistance. Resistance is always cumulative. As resistance increases in a circuit, current flow decreases. In a fixed-voltage system, resistance controls the current flow: the greater the resistance, the less the current.
resistivity
— expressed in ohm meters and dependent on temperature, a fundamental material property that quantifies how strongly a material opposes the flow of electric current regardless of its volume or shape.
Sn
— chemical symbol for tin (from Latin: stannum)
sub-circuit
— one of two or more circuits that share direct or indirect connections to the power bus and ground bus of a power source
terminal
— a point of electrical connection for the effluence or return of current
voltage
— the quantification of potential expressed in volts (or joules per unit charge). Voltage is the difference in electric charge that exists between two discrete points that are separated by a distance greater than zero and represents the amount of force available to equalize the electric charge between those discrete points. Within an electric circuit, voltage is the potential, measured relative to ground, that is available to force the movement of electric charge or current.
voltage drop
— expressed in volts, the work performed in forcing the migration of electric charge. Within an operating circuit, the amount of voltage necessary and consumed in forcing current flow through a resistance. Current must flow for the voltage to drop. When no current is flowing, the measured voltage is limited to two possible states: either the power source voltage or zero. The relative decrease in voltage between two discrete points that are separated by a resistance while current is flowing between those two points through that resistance. Voltage drop is the charge differential created across every circuit and circuit component that exhibits resistance while current is flowing through that circuit and its components. The source voltage is distributed proportionally across every resistance in an operating circuit, such that all of the applied voltage is consumed. That is, some portion of the source voltage is consumed by each resistance in the circuit, such that 100% of the voltage is used. Voltage is
always
consumed
, decreasing to zero, in the process of forcing current flow.
APPENDIX
Ohm’s Law
— A mathematical expression that precisely defines the interdependent relationships between DC voltage, current, and resistance within a closed operating circuit, traditionally written as:
E = IR
where
E
is the Electromotive Force measured in volts,
I
is the Intensity of Current Flow measured in amperes, and
R
is the electrical Resistance to Current Flow measured in ohms. Ohm's Law expresses the voltage expended or used (the voltage drop) in forcing current flow through a resistance.
Rewritten,
I =
E
R
and
R =
E
I
Ohm's Law applies only to complete, operating circuits and is arguably the most fundamental, hence the most important, rule governing DC circuit operation. Comprehending and committing Ohm’s Law to memory will benefit immeasurably your perception, diagnostic acuity, and confidence in solving automotive electrical problems. Essentially, Ohm’s Law states that current is directly proportional to voltage and inversely proportional to resistance (see the preceding middle equation). If voltage increases, current increases. If resistance increases, current decreases. If any two of the three variables are held constant, the remaining variable
must
adjust to maintain equality. If only one variable is held constant, the remaining two variables can change, but are bound within definable limits to maintain equality. Using Ohm's Law for occasional circuit calculations can be useful, but being completely conversant with the dynamic relationships it reveals between voltage, current, and resistance is utterly invaluable! It is only necessary to memorize the first equation shown, since the remaining two equations can be derived quite easily.
Last Edit: June 19, 2026, 10:03:24 pm by bd
(Moderators:
bd
