Author Topic: Compression Test Results  (Read 4724 times)
Offline Golf
« on: October 15, 2017, 06:12:23 pm »
All cylinders between 145-150psi - except 7... Cyl #7 at 120psi.  10% would be no lower than 135.
White smoke from driver (cyl 7 side) tail pipe at idle - low to nonexistent oil pressure at idle after warm up.
Where to start?
2002 Mustang GT Convertible (Mineral Grey)
2003 Mustang GT Convertible (Triple Black - wife D/D)
2013 Ford F550 XLT (Tow Truck - my D/D)
2006 Kawasaki Vulcan 750
1984 C10 Custom Deluxe
Re: Compression Test Results
« Reply #1 on: October 15, 2017, 06:45:06 pm »
#1 post the details on your truck, #2 what are you trying to determine by doing a compression test? #3 How are you checking your oil pressure, is there a noise issue? #4 Tell us what your concern is, what is it you are trying to determine or do?
Offline Golf
« Reply #2 on: October 15, 2017, 08:47:49 pm »
84 c10 305... Saw smoke in exhaust wanted to see if rings and I was changing plugs anyway. Truck was free but didn't want to sink cash in motor if it's done for
Offline jetman
    • Squarebody Referance Library
« Reply #3 on: October 16, 2017, 08:44:20 am »
Sounds like the numbers on my truck's 305.  In spite of the condition, I drive it almost every day making deliveries, will be driving it till it drops.
Then organize a re-ring,  bearing and/or crank kit and back on the road with her.
Offline Golf
« Reply #4 on: October 16, 2017, 06:08:44 pm »
Truck runs really well but aftermarket oil pressure gauge showing next to 0psi at idle which is why I did compression test. Has plenty when cold, instantly jumps when given throttle. Heard maybe try a different weight oil and some marvel mystery oil
Offline Jerr-conn
  • Retired tool maker
« Reply #5 on: November 21, 2017, 08:44:26 am »
Golf--- I have a similar oil pressure problem with a after market mechanical oil gauge. What brand name Gauge do you have? I'li have to check my gauge because right now I don't know what name
Brand mine is. Maybe the same.
Jerry
Offline ChevyK20BBC
« Reply #6 on: November 22, 2017, 10:19:20 am »
Ive read before on some engines oil pressure can be as low as 5- 10 psi at idle, as long as it comes up with RPMs. Also Adding some Lucas oil stabilizer will bring the pressure up quite a bit. But that may be just masking the problem. Another thing to check could be a defective or clogged oil filter could give you a low pressure reading, or a worn oil pump,clogged pickup screen, bypass valve hanging open?
