Engine/Drivetrain
TH-350 vs. TH-350C filters:
Topic: TH-350 vs. TH-350C filters: (Read 3671 times)
Stewart G Griffin
October 27, 2017, 02:11:40 pm »
Is the trans filter for a TH-350C different from a regular TH-350?
i thought the 350C has a notch cut out of it vs. a regular 350 which is square.
However, the AC Delco site lists the same filter as compatible with both transmissionses.
i don't want to drop the pan unless i'm sure i have the right filter. i have a 350C
Last Edit: October 27, 2017, 02:28:42 pm by Stewart G Griffin
Re: TH-350 vs. TH-350C filters:
October 27, 2017, 03:21:44 pm »
250-350/c's are all the same. You're good
⌠ŻŻŻŻŻ' [☼===☼]
Stewart G Griffin
November 11, 2017, 10:32:15 pm »
Yes, it turned out that the TH-350 and TH-350C use the exact same filter.
BTW on these trucks with TH-350's, the back two pan bolts are blocked by the trans crossmember, BUT you can get to them with a 1/4" drive socket----and some patience.
November 12, 2017, 07:07:30 am »
Check to see if your transmission mount is good and not sagging
⌠ŻŻŻŻŻ' [☼===☼]
Stewart G Griffin
November 12, 2017, 11:35:38 am »
trans mount is new and fine----an energy suspension mount.
Engine/Drivetrain
