Author Topic: Timing Issue.....I think.  (Read 3636 times)
Offline Rapid Roy
  • Euless, Texas
« on: October 28, 2017, 07:14:31 pm »
74 C10 350 TH350. Stock (original) engine. Upgraded OEM points distributor to HEI. I removed coil, cap and wires. Turned harmonic balancer mark to 0. Checked where rotor was pointing before removing old dist. It was pointing to #6 plug. From info I have found, it should point to #1. Installed HEI and set rotor to point to #1 and would hardly run with dist turned all way counter clockwise. Is this a timing issue with cam and crank?
Mopar by Birth
Chevy by Choice
Offline FlatBlack77
Re: Timing Issue.....I think.
« Reply #1 on: October 29, 2017, 08:38:52 am »
did you start it then turn the distributor by hand to see if you could find a spot where it ran good? at least to keep it running while you time it with the light
« Reply #2 on: October 29, 2017, 09:22:22 am »
If you didn't rotate the crankshaft another full revolution and left everything the way you took it apart, then you put the distributor in 180° off. You should have put the distributor in pointing at #6 if that was where you removed it. You were on TDCC #6 cylinder.
