Author Topic: 84 C10 Longbed- Deciding which lowering kit  (Read 8781 times)
Offline ryanc
« on: November 05, 2017, 10:48:10 am »
Hey guys, New to the C10 world and looking to lower my truck. I have been doing a bunch of reading about different kits and trying to decide what to go with. So im looking for personal experiences, input, suggestions, info etc. After reading so much it becomes a blur!
Currently Im looking at 4/6 drops from Belltech, DJM, Western Chassis, and McGaughtys (open to any other suggestions)
If I recall correctly, there are some issues with certain drop spindles and stock rims?
Also, I have seen some kits that use a C notch, while others do not, or have it as an option. for example, Western Chassis, the kit offers 6 inches of drop, what is the reason to opt for the C notch kit with it then?
Any input would be great! thanks in advance
Offline JBlanks
Re: 84 C10 Longbed- Deciding which lowering kit
« Reply #1 on: November 05, 2017, 09:27:36 pm »
I'm a bell tech guy all the way, they make great products.  The c notch is a must for the 6 inch drop in the rear to allow the suspension to travel for a good ride.
Offline ryanc
« Reply #2 on: November 08, 2017, 06:52:24 pm »
ok, thanks. do you know if the belltech kit allows for the use of the stock 15's?
Anyone else have any input?
Offline MrFiveOh
  • The Local Po-Po
« Reply #3 on: November 13, 2017, 09:34:45 am »
Cnotch is only required for more than 6 inches of drop in the rear and you plan on carrying heavy loads. CUt off the rear bump stops. I have a 6 inch flip with bumps cut off and have more then 3 inches of clearance.
1974 C-10 AKA "Smurf"
