Author Topic: Edelbrock Vs. Trick Flow  (Read 8105 times)
Offline gosaspurs
« on: January 31, 2006, 08:49:00 pm »
Hello all,
Okay I have a 1976 K10 with a 350 that I'm attempting to make into a real mean machine.  With the initially stock 350 I have added an edelbrock rpm performer cam, edelbrock air gap intake, edelbrock AVS 800cfm carb, and headers.  The motor was also bored 30 over and a gear drive was added.  My initial intention was to do the edelbrock RPM performer package.  Recently though I have had many tell me not to go that route.  My other possible engine would involve trick flow's 23 degree heads.  Has anyone run either of these packages.  If so what did you like,, dislike?  Any other suggestions?
Matt
1976 K10
P.s. It is a 4x4 running 35/12.5/15 Tires with 3.73 gears
Edited by: gosaspurs at: 1/31/06 8:50 pm
Offline ChevyGuy
heads
« Reply #1 on: January 31, 2006, 09:14:00 pm »
We had really good luck with stock 487 and camel hump heads. The best aftermarket we seem to run was the Dart Sportsman II's.
Offline cruppert77
heads
« Reply #2 on: February 01, 2006, 06:17:00 pm »
I am using a Trick Flow engine kit that came with heads, cam, stuff like that. They seemed to get better hp than the Eldelbrok stuff that I looked at. Very nice parts, but I am having trouble looking for headers right now. I don't know how hard it will be to find, I just started loookig.
Offline gosaspurs
Headers
« Reply #3 on: February 01, 2006, 07:04:00 pm »
Thats the kit I was thinking of running.  I spoke with summit about the header problem just yesterday.  They told me that hedman and hooker are the only companies that make headers for angle plugs.  So try those two companie and if all else fails, calling the summit tech line and asking for the exact part numbers always works.
Offline cruppert77
Re: Headers
« Reply #4 on: February 02, 2006, 03:54:00 pm »
Summit found me one pair of Hooker super comps that were ceramic coated for almost $600. I am going to keep looking
Offline gosaspurs
Headers for Trick Flow Heads
« Reply #5 on: February 10, 2006, 08:17:00 pm »
After calling summit, hedman and hooker in regards to headers for the trick flow 23 degree aluminum heads, I finally emailed Trick Flow and got this response.  Hope it helps.
Matt,
All of our heads have angled sparkplugs.
The location / angle of the sparkplugs in our head do not usually interfere
with most headers. However, If you should happen to get into a tight spot,
Accel makes a special short plug (It is 1/4" shorter) to help alleviate
fitment issues.
Hooker # 2452 fits fine...
Thanks,
        Art Kakiou TFS Tech Advisor
        Email: akakiou@trickflow.com
        Tele: 330-630-1555 ext:6324
The hooker headers listed above run for $329.88
