Author Topic: noise in speedometer?  (Read 5140 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
« on: November 25, 2017, 10:41:53 am »
Every since I bought this truck. [1986 Chevy c10 4.3 v6 A.T. transmission] I have heard a scrubbing noise the colder it is out side the worse it is. I first thought it was a front drivers side wheel bearing it was not. Then thought it was the exhaust it was not. I now believe it is either the speedometer or cable. At very low speeds it doesn't  make a sound. And on hot days it may start out noisy but as it warms up it fades away. should I oil the cable and speedometer and with what? I thought about white lithium grease in a spray but this to gets stiff in colder weather. Has anyone seen or heard of this with the speedometer or cable? If so what was the fix. Thanks Smitty31.
« Last Edit: November 25, 2017, 11:04:44 am by Smitty31 »
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Re: noise in speedometer?
« Reply #1 on: November 25, 2017, 11:00:24 am »
Disconnect the speedometer cable from the transmission and go for a short drive to see if symptoms go away.  Speedometer cables are easy enough to lubricate.  See the first entry in Common causes of "bouncy" speedometer needles.
Offline Smitty31
« Reply #2 on: November 25, 2017, 11:06:36 am »
ok i will try that. Will it leak transmission fluid?
« Reply #3 on: November 25, 2017, 01:10:11 pm »
It won't leak fluid if you just disconnect the cable from the ratio adapter/transmission.
