Author Topic: water neck  (Read 5820 times)
Offline chevn-up
water neck
« on: November 25, 2017, 11:20:02 am »
Ok, got this after-market water neck with rubber O ring. Anybody have a preferred method of installing ? Gasket/no gasket, sealer/no sealer etc. etc. Thanks.
Offline Stewart G Griffin
Re: water neck
« Reply #1 on: November 25, 2017, 11:37:00 am »
What brand is this?
Offline chevn-up
Re: water neck
« Reply #2 on: November 25, 2017, 11:54:36 am »
Not sure, I only know it's for chevys.
Re: water neck
« Reply #3 on: November 25, 2017, 11:56:52 am »
The o-ring is designed to replace the gasket.
Offline chevn-up
Re: water neck
« Reply #4 on: November 25, 2017, 05:20:47 pm »
The O-ring is removable, so I know a gasket and sealer will be ok.
Offline AZ4X4SQBDY
Re: water neck
« Reply #5 on: November 25, 2017, 09:42:37 pm »
This
Chrome plated thermostat housings tend to leak unless you sand the chrome from the mating surface to the manifold. The housing you purchased uses a o ring instead of the gasket to seal it, you need to use the o ring.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Re: water neck
« Reply #6 on: November 26, 2017, 08:30:50 pm »
Actually that looks like a Moon unit.  That is probably good quality.  But most chrome necks, i'm afraid-------are not good quality............and will leak.
Offline Henry
Re: water neck
« Reply #7 on: December 01, 2017, 12:06:17 pm »
Hi Chevn-up:
The gasket/o-ringmating surface on the intake manifold is just as critical as the gasket/o-ring mating surface on the water neck. If yours is in good shape just make sure it is very clean and smooth. If you need to lightly sand it to clean it up you should use circular motion so the sand marks do not cause leakage. If it has pitting, you are probably going to have problems with the o-ring. A flat gasket has a lot more surface area to help seal the pitting problems. If you get it all together and you get some seepage, see if a re-tightening stops the leak...if not, I would recommend getting a water neck that uses a flat gasket with sealant. I personally like the cast iron water neck for gen II Chevy trucks.
Good luck,
Henry
Offline blazer74
water neck
« Reply #8 on: December 01, 2017, 04:58:53 pm »
Shouldn’t need sealer with the Oring style unless any of the mating surfaces are pitted and then just a thin transparent amount of sealer to fill the pitting.
Surfaces have to be smooth for the Oring to work alone.
Don’t bother with a cheap pot metal or chrome water neck, it won’t last.
« Last Edit: December 01, 2017, 05:03:18 pm by blazer74 »
