Author Topic: project onion rings  (Read 224553 times)
Offline chevn-up
Re: project onion rings
« Reply #105 on: August 25, 2020, 05:44:49 pm »
ok.
Offline macr0w
« Reply #106 on: September 14, 2020, 07:36:58 am »
Looks killer but, where's those sweet rims?
Offline chevn-up
« Reply #107 on: September 15, 2020, 04:18:21 am »
Been busy renovating half of my house. The truck has been put on hold for now. These are a few older pictures that I'm just throwing out here for ya'll. When I get back on it, oh yea, the rims will be the new version truck.
Offline chevn-up
« Reply #108 on: September 15, 2020, 04:21:02 am »
last one..
Offline chevn-up
« Reply #109 on: November 25, 2020, 01:43:58 pm »
Finished up with the steering gear. The re-build was easy.
Offline chevn-up
« Reply #110 on: November 25, 2020, 01:48:17 pm »
Adjusted the sector shaft and the input shaft pre-load. A spanner wrench makes it simple. I didn't have one, so I improvised. Worked out great.
Offline chevn-up
« Reply #111 on: November 25, 2020, 01:51:00 pm »
I went from this original shaft...
Offline chevn-up
« Reply #112 on: November 25, 2020, 01:51:49 pm »
 To the Jeep shaft, no doubt.
Offline chevn-up
« Reply #113 on: November 25, 2020, 01:52:40 pm »
 Happy, Happy.
Offline Shifty
  • I bleed Bowtie red...
« Reply #114 on: November 25, 2020, 02:34:09 pm »
 8)
98 C2500 ext cab longbed
Offline chevn-up
« Reply #115 on: September 22, 2021, 06:54:26 pm »
Okay, everything blasted, painted, and pre-assembled. I won't bore you with all the details. Ya'll know how these front ends go together.
Offline chevn-up
« Reply #116 on: September 26, 2021, 05:35:07 pm »
A weekend of wrench'n. Some highlights are 3" dropped spindles, 1" dropped springs, offset upper control arm shafts, (for more camber), aftermarket upper control arms, and raised stabilizer bar brackets.
« Last Edit: September 26, 2021, 05:51:47 pm by chevn-up »
Offline chevn-up
« Reply #117 on: September 26, 2021, 05:37:51 pm »
Also added this door hinge spring that was missing since I've had the truck. Wow, the door stays open now.
Offline Shifty
« Reply #118 on: September 27, 2021, 09:40:39 am »
 8)
Offline chevn-up
« Reply #119 on: November 26, 2021, 03:47:14 pm »
 Problem with the front brake hoses. The tall line is for my year truck (85). The "shorty" line is for a 1980 C10. I can't use the tall line because it hits my aftermarket spindle, making it impossible to install correctly. The other fits just fine. Problem solved. Just a heads-up, hoping this helps others.
