Author Topic: project onion rings  (Read 224517 times)
Offline Shifty
  • I bleed Bowtie red...
Re: project onion rings
« Reply #135 on: April 07, 2023, 05:14:02 pm »
You do nice work sir!  Looks great!  8)
98 C2500 ext cab longbed
Offline chevn-up
« Reply #136 on: April 08, 2023, 09:08:07 am »
Thanks Shifty. I see my digital camera takes lousy pics. Gonna use my android from now on. Starting to look like a truck again.
Offline Shifty
« Reply #137 on: April 08, 2023, 11:24:03 am »
Whatcha got going with the heater hoses?  Do I see copper pipe?
Offline chevn-up
« Reply #138 on: April 08, 2023, 12:39:23 pm »
yep. just moved the hoses inboard a bit since I am not using the inner fenders.
Offline Shifty
« Reply #139 on: April 08, 2023, 12:45:45 pm »
I figured it was something like that!  ;)
Offline JohnnyPopper
  • Old Goof
« Reply #140 on: April 08, 2023, 03:07:50 pm »
Great Progress!
What is your thinking on not using inner fenders?
1980 C-10 under construction
Offline chevn-up
« Reply #141 on: April 08, 2023, 06:22:12 pm »
JP.. it's what I want to do.
Offline chevn-up
« Reply #142 on: April 08, 2023, 06:44:32 pm »
the replacement radiator
Offline chevn-up
« Reply #143 on: April 08, 2023, 06:47:29 pm »
mocked-up the intake today. I believe it will work.
Offline chevn-up
« Reply #144 on: April 08, 2023, 06:49:22 pm »
another
Offline Mr Diesel
  • Aaron
« Reply #145 on: April 09, 2023, 09:05:03 am »
That looks really good. Very clean and professional.
I think you will find that intake elbow on top of the carb to be restrictive. I built one similar for a stockish .305 and ended up ditching it because it choked out the engine at mid-upper rpm. Cant even imagine if I tried to put it on a 350 with some performance improvements.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline chevn-up
« Reply #146 on: April 09, 2023, 06:08:36 pm »
MrD. You are right. I have read the articles/reviews on this carb plunium. With my 600cfm carb and 273 rear gears, I won't be hitting over 4,000 rpm very often. Nothing that can't be changed if needed. Thanks for the input.
  • Old Goof
« Reply #147 on: April 09, 2023, 08:00:45 pm »
I get it- why hide all the beauty you created? BUT, you'll rue the day you drive through a mud puddle.  :(
Offline chevn-up
« Reply #148 on: April 10, 2023, 10:19:09 am »
Yep JP. Hard to get it pretty, harder to keep it pretty.
  • Old Goof
« Reply #149 on: April 10, 2023, 11:55:15 am »
So you went with a shorter radiator to allow for the Air Filter box? In the pic it looks shorter but I could be wrong.
