Author Topic: project onion rings  (Read 299906 times)
Offline chevn-up
Re: project onion rings
« Reply #150 on: April 11, 2023, 03:51:42 am »
same size, single row...29x20 core, overall length 33 1/2. plastic ends. Took a little searching the net to find. Matches the rubber bushings and upper brackets also.
Offline chevn-up
« Reply #151 on: April 30, 2023, 10:03:12 am »
Installed the front side lines of the cooler. Used NBR hose. Should be ok.
Offline chevn-up
« Reply #152 on: April 30, 2023, 10:07:28 am »
Also, finished with the front wire harness. All new bulb sockets. Everything soldered, as well as dielectric grease and shrink-wrap on all splices. Pert near new again.
Offline chevn-up
« Reply #153 on: April 30, 2023, 10:08:50 am »
Now to start on these.
Offline chevn-up
« Reply #154 on: June 24, 2023, 08:02:03 pm »
ok, all fab and painting done.
Offline chevn-up
« Reply #155 on: June 24, 2023, 08:04:41 pm »
wow, guess I need to figure-out my camera /re sizing options.
Offline chevn-up
« Reply #156 on: June 24, 2023, 08:06:33 pm »
here it is, I hope
Offline chevn-up
« Reply #157 on: June 24, 2023, 08:07:50 pm »
Offline chevn-up
« Reply #158 on: June 24, 2023, 08:08:48 pm »
turns out the camera more work than truck.   sorry
Offline chevn-up
« Reply #159 on: June 25, 2023, 11:40:59 am »
bagged and tagged all the bolts and shims, so it should go back together ok.
Offline JohnnyPopper
  • Old Goof
« Reply #160 on: June 25, 2023, 05:10:42 pm »
Looking good brother!!! ;)
1980 C-10 under construction
Offline Shifty
  • I bleed Bowtie red...
« Reply #161 on: June 26, 2023, 10:35:11 am »
Excellent!  8)
98 C2500 ext cab longbed
Offline chevn-up
« Reply #162 on: July 04, 2023, 07:55:12 am »
Finished grafting the front wire harness back in..... It's alive!
Offline chevn-up
« Reply #163 on: July 04, 2023, 07:57:33 am »
got everything to finish the front, in due time
Offline chevn-up
« Reply #164 on: July 04, 2023, 08:12:30 am »
Time to get these back in. Delivered the driveshaft to my local driveline shop for new parts and a speed balance. Gonna finish up with the radiator install, and then I will fill her with fluids and maybe putt around the neighborhood.
« Last Edit: July 04, 2023, 08:15:02 am by chevn-up »
