Author Topic: t case #'s  (Read 8486 times)
Offline bfofish
t case #'s
« on: March 08, 2006, 05:31:00 pm »
anyone know if a 241c w/272ratio will bolt up to a 700r trans? i currently have a 208c 2 w/261ratio,that is slipping out of 4wheel while i am snowplowing(was told it needs a rebuild).
will the gear ratio change be a problem?
Re: t case #'s
« Reply #1 on: March 09, 2006, 06:55:00 am »
You sure it dosn't need the shifter adjusted?
I put new motor mounts in my 86 3/4ton and then the tcase sliped inbetween 2 and 4 wheel drive. I took the linkage out freed it up, reinstalled, and adjusted. It never bothered again.
As far as bolting up, as long as the output input shaft diamiter and spline count are the same it will work. If i rember correctly there is 28 spline and 32 spline inputs on the 208s.
Whats is the 241 outr of? I have only ever seen 203, 205, and 208s t cases in C / K and V / R modle trucks.
Offline 1976Scottsdale
Re: t case #'s
« Reply #2 on: March 09, 2006, 12:21:00 pm »
The 241c came in some 89-91 fullsize blazers and in 4x4 s-10's.
Offline bfofish
Re: t case #'s
« Reply #3 on: March 09, 2006, 04:53:00 pm »
hey blazin what type of adjuting did you do to the linkage? the 241 t case is out of a 91 suburban.
Re: t case #'s
« Reply #4 on: March 09, 2006, 11:22:00 pm »
Thats what I thought Scotsdale, but I couldn't remember the # off the top of my head.
Which side is the front output on bfofish?
The shift linkage is threaded. I removed, it freed it up, reinstalled it, & adjusted it so the shifter was locked into 4 wheel drive.
Edited by: Blazin at: 3/9/06 11:22 pm
Offline bfofish
Re: t case #'s
« Reply #5 on: March 10, 2006, 11:38:00 am »
the output is on the right.i'll be looking into this over the weekend.thanks for all the info,i'll let you know what the outcome is.
Offline bfofish
Re: t case #'s
« Reply #6 on: March 11, 2006, 06:43:00 pm »
did some adjusting to the linkage today ,all is good . thanks for all the help guys.
