Author Topic: Bench seat fit  (Read 10149 times)
Offline AmericaMade
Bench seat fit
« on: January 29, 2018, 06:41:40 pm »
Have an 83’ scottsdale c10. Looking to put a bench seat in. Will a 77’ seat fit? This is the 77’ seat
« Last Edit: February 01, 2018, 03:12:25 pm by Irish_Alley »
1983 C10 Scottsdale 383 Stroker TH/350 Holley 850 Double pumper carb
Online zieg85
Re: Bench seat fit
« Reply #1 on: January 29, 2018, 08:27:22 pm »
can't see the pictures but if it is a stock seat from a 1977 into a 1983, yes it will bolt in.  The drawbacks are the seat belts would go between the seat back and bottom, not through the bottom like the 83.  Now the belts will be tight and if you need the seat up at all or you not skinny you may not get the belt buckled.
Offline Rapid Roy
  • Euless, Texas
Re: Bench seat fit
« Reply #2 on: January 29, 2018, 08:28:43 pm »
No pics to see. Welcome to the site.
Mopar by Birth
Chevy by Choice
Offline AmericaMade
Re: Bench seat fit
« Reply #3 on: January 29, 2018, 08:50:21 pm »
https://ibb.co/mSwTDm
https://ibb.co/jdoKKR
Another image host hopefully this works.
I have 94’ suburban seats in it presentyl and theyre fine. But I want thr bench seat I prefer that look. I bought it with the suburban seats, so...
« Last Edit: January 29, 2018, 08:54:42 pm by AmericaMade »
Offline AmericaMade
Re: Bench seat fit
« Reply #4 on: January 30, 2018, 02:04:13 pm »
I uploaded a new pic... if you say it will work Im going to go for it. I gather the bolt pattern is the same from 73-87
Online zieg85
Re: Bench seat fit
« Reply #5 on: January 30, 2018, 02:10:52 pm »
it will bolt in and sit correctly
Re: Bench seat fit
« Reply #6 on: February 01, 2018, 03:14:03 pm »
fixed the top post so you can see the images without clicking on the link. click "modify" to see what i did. but i right clicked on the image then copied the image address and put that in the image code
