Author Topic: Will the rt rear door match from an '82 C20 Suburban & an '84 C20 P/U?  (Read 3904 times)
Offline srodster
I need to replace my right rear door on my '84 C20 P/U, and found an '82 Suburban C20.
Is it the same door?
I have not looked at it in person, but only saw photos......
Re: Will the rt rear door match from an '82 C20 Suburban & an '84 C20 P/U?
« Reply #1 on: February 27, 2018, 08:44:12 pm »
your question is a bit confusing cause of a small detail that was left out
is the c20 a reg cab or crew cab?
you can swap a crew cab and burban doors but a rear burban door wont fit the regular cab door.
Offline srodster
« Reply #2 on: February 28, 2018, 06:45:27 pm »
The '84 is a crew cab.
So, wasn't sure if an '82 Suburban right rear door was stamped the same as an '84 crew cab right rear door.
I'm at a little disadvantage because I've only seen a poor quality photo of the Suburban door.
yes theyre the same door.
