Author Topic: 84 C10 clutch rod hole locatioin  (Read 3965 times)
Offline Ronno6
  • Elder Student
« on: April 06, 2018, 11:27:53 am »
I have seen a few old threads on the topic, but I am unable to view any photographs.
I am converting my '84 Chevy C10 from automatic to 4 speed, and
need the location of the hole for the clutch linkage to pass thru the firewall/floorboard.
Is there a way to convey this dimessionally?
Or, can someone provide a photo,please?
Is there a dimple or other marker present on the body ?
Do I need to do something in order to view photos?
Thanks.
You can lead a man to water, but yoiu can't keep him from pissing in it.
Re: 84 C10 clutch rod hole locatioin
« Reply #1 on: April 06, 2018, 12:21:11 pm »
There are 2 dimples in the cab, best seen if you peel back the insulation and floor covering around the steering column area
Offline Ronno6
  • Elder Student
« Reply #2 on: April 06, 2018, 01:35:58 pm »
Thanks.
I looked there and found 3 dimples.
Makes sense as the boot has 3 mounting holes.
Was this a test??
Thanks again!
« Reply #3 on: April 06, 2018, 01:56:43 pm »
Was this a test??
you passed
