Author Topic: 83 chev K20 military  (Read 6100 times)
Offline 101 airborne
« on: April 25, 2018, 07:34:33 pm »
What is the max tire size with out body or suspension lift mods ? I have 4.56 gears with 16.5 x 9.50 which measure about 29.5 tall. I want to change to 16 inch rims but don't know which backspacing to get to work with bigger tires for clearance. Thanks from Kansas .
Re: 83 chev K20 military
« Reply #1 on: April 25, 2018, 08:04:15 pm »
i may be 100% wrong but i thought all military trucks were k30s except for the k5
also take a look here
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31301.0
i did a little information gathering about tires/lifts. i have a 91 k3500 crew cab, with no lift and i was able to squeeze 33s under mine
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: April 25, 2018, 09:13:41 pm »
Canadians used K20 and K30, not to familiar with the time frame, but did use GM trucks earlier then the US.
As for tires and backspacing, a no lift, 33" may fit, 32" definitely.  A thinner rim and 235/85/16s will look good, with a 4" backspace. As long as there is less then 4" backspace I think any other width of tire can also be accommodated.
 1986 Chevy K30(under repair)
