Author Topic: Mechanical Fuel Pump Boss  (Read 4547 times)
Offline Doppleganger
« on: July 12, 2018, 02:22:07 pm »
Been looking for that random, yet existing vortec block with the block off plate to use a mechanical fuel pump. I've got a Q-Jet all redone and would prefer a mechanical pump over an electric one.
Local yard has a few vortec blocks.....but on only one did I see a plate. The rest looked like this:
This doesn't look like the cast blank that requires the million dollar jig to mill out. What do any of you fellas make of it?
As always, TIA
Re: Mechanical Fuel Pump Boss
« Reply #1 on: July 12, 2018, 05:22:52 pm »
I would put an in tank fuel pump and an inline fuel pressure regulator.
« Reply #2 on: July 13, 2018, 08:06:52 am »
Seems the ones like my pic are not drilled out. There's one at the yard with a plate so will check that out.
I'm using a mechanical pump thats easy to service - dont want anything electric with a regulator, etc.
« Reply #3 on: July 20, 2018, 11:33:31 pm »
what vortec block are you looking for? true votecs started in the mid 90s and would require something like 60 lbs of fuel pressure, not sure if a mechanical pump would do this. so are you just looking for a tbi motor (87-95)? or am i forgetting or showing my ignorance to the vortec motors?
Offline talan1979
« Reply #4 on: July 23, 2018, 09:17:17 pm »
no a manically driven pump wont put out the pressure you need u might have to go with a electric pump or your going to have problems with power and speed
