Author Topic: Carb to tbi conversation  (Read 18278 times)
Offline st3vomettler
Re: Carb to tbi conversation
« Reply #30 on: August 08, 2018, 06:05:29 am »
No but I been doing some research and on 88-96 there’s a different style neutral safety switch for Manuel trans and this truck has it and I didn’t now what it was till now I’ll try to post a pic of it
77 c10 Silverado 350 nv3500 5spd
« Reply #31 on: August 08, 2018, 06:08:03 am »
Neutral safety switch
« Reply #32 on: August 08, 2018, 07:27:04 am »
not 100% sure but would the engine crank at all in a manual without pressing in the clutch? thought it wouldnt do anything.
but did you hook the OBD system up? is there a way to get the check engine codes if there was any?
« Reply #33 on: August 08, 2018, 10:11:43 am »
try this
« Reply #34 on: August 08, 2018, 10:22:07 am »
Heres the A4 if you need them
« Reply #35 on: August 08, 2018, 10:28:05 am »
and A6 if you need it
« Reply #36 on: August 08, 2018, 11:17:04 am »
Thank you I’ll get a scan tool from work to see if it can pull codes
« Reply #37 on: August 13, 2018, 08:34:58 pm »
Finally got my truck running. There were some more connectors by computer that wasn’t hooked up that went from fuse block back to computer and hooked my distributor tach to computer and it fired up now on to new problem with clutch hydraulic system.
Offline haroldwca
« Reply #38 on: August 28, 2018, 09:20:27 pm »
Just a thought here:  On a vehicle that was built before computers controlled spark, fuel delivery, and practically everything else, most electrical circuits were designed to switch OFF when the key is in the START position, to send the maximum current to the starter.  Converting to an electric fuel pump requires the voltage to the fuel pump to be ON even when the key is in the START position.  If the voltage to the pump is inadvertently connected to a circuit that is OFF with the key in START position, the vehicle will not start due to no fuel pressure.  You probably already know that, but I throw it out here just in case.
