Author Topic: 250 inline  (Read 6403 times)
Offline 1980cdeluxe
250 inline
« on: May 02, 2006, 03:01:00 pm »
Well, I put the 78 I bought for 200$ back together and realized it ran really good. I decided i'm going to put it on the road untill I fix my 4x4. I have a question though, about the manifold on the 250 inline. The bolts that holds the manifold to the head, where can I get one of them with the piece on it? The piece looks sort of ovalish that keeps the manifold tight back against. I have some on it, that came with the motor (the manifold was removed when I got the truck) but I still have a slight leak and i'm sure another one of those are the reason. It has the bolt, but it's missing the piece. Anyone know what they're called, and where I could get one?
Thanks
Offline Z28 c10
Re: 250 inline
« Reply #1 on: May 02, 2006, 05:38:00 pm »
I'm not too sure exactly what your talking about, but it sounds like it could be your EGR valve mounting pad.
 JayTater
 Z28 C10
Offline 1980cdeluxe
Re: 250 inline
« Reply #2 on: May 02, 2006, 05:44:00 pm »
It's not Egr, the bolts goes through the pieces. Their are multiple ones. Some short (inch and a half), some long (3 inchs?).
Offline 1980cdeluxe
Re: 250 inline
« Reply #3 on: May 02, 2006, 06:58:00 pm »
example of one on this motor, pic I found on ebay
img321.imageshack.us/my.p...1717kr.jpg
also more information reguarding which bolts need one of those pieces and which ones dont.. It's kinda hard to see what i'm talking about, but I circled it on black (look for manifold bolt in the front).
Edited by: 1980cdeluxe at: 5/2/06 5:59 pm
Offline roundedline
Re: 250 inline
« Reply #4 on: May 02, 2006, 05:58:00 pm »
You are talking about the basically U shape pieces that go between each intake/exhaust port correct.  They are used to retain the intake/exhaust at the same time.  If you are missing any, you will have a leak.
Bad thing is, I don't have a clue where to get any...
You can try here:
www.sissellsautomotive.com/
cliffordperformance.net/
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
