Author Topic: Spark plug preferance  (Read 8785 times)
Offline Z28 c10
« on: May 02, 2006, 07:11:00 pm »
Hey guys, just wondering what type of plugs you guys run, prefer, never use again,etc. I've been running AC R43's for about three months now, since I put in the new cam, and they're not fouling out, but they're breaking down already. I use to run NGK's in my 5.0 and my SC 3.8 cougars and rarely ever had problems with them but I've been told by a couple buddys not to use them in Shirley, not quite sure why but, oh well. Just wanted to get a little input from ya'll.
 JayTater
 Z28 C10
Offline 123 pugsy
Re: Spark plug preferance
« Reply #1 on: May 02, 2006, 08:26:00 pm »
I've used NGK once and they didn't perform well.That was about 10 years ago.Ever since,I've been using AC Delco with no problems.
Pugsy
76 C10 LWB
TPI 350
Offline Redneckchevy
    • Photo Bucket
spark plugs
« Reply #2 on: May 03, 2006, 05:25:00 am »
I dont no if u think this is a good Plug but iv been using bosch platinum 4 since thay have came out and i never had any problums...thay have lasted in cars with O ring leaks ...Fuel flooding the cylinders. Pre iignition and dont let any one trick you into thinking that that get so hot that thay will burn a hole in ur piston..a bud at my work swares that thay will..funny thing is he never used them
« Reply #3 on: May 03, 2006, 07:16:00 am »
I have always used ACs, tried Autolites over a year ago in my 55 ( 355 motor ). Have had no problems with them yet. Reason I tried them is a freind of mines dad said that is what they run in there late model 358 chevy motor and had better luck with them than ACs.
Offline Z28 c10
« Reply #4 on: May 03, 2006, 05:01:00 pm »
Guess I might step down to the R45's. It's worth a shot. Thanks guys.
 JayTater
 Z28 C10
Offline 123 pugsy
« Reply #5 on: May 03, 2006, 08:20:00 pm »
Hey Z28,what do the #'s 43..45.. stand for? Curious.
Pugsy
76 C10 LWB
TPI 350
Offline Z28 c10
« Reply #6 on: May 03, 2006, 08:35:00 pm »
R43 is a hotter plug than the R45.
 JayTater
 Z28 C10
Offline roundedline
« Reply #7 on: May 04, 2006, 10:03:00 am »
I generally run R45TS' in mine BBC, I have used either AC, Bosch Platinum or Autolite and had good luck with each of these.  Generally I run AC's though.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
