Author Topic: wiring  (Read 5097 times)
Offline 1987V20
wiring
« on: May 07, 2006, 11:35:00 pm »
On a 1987 pickup with 2 tanks how does the switching valve work?  Does the power for the pumps run through the valve or does it run directly from the relay back to the pumps?  I have a dead truck and I have already replaced the fuel pump in one tank(it really was bad) and now I still get nothing.  I know it will run because I fed it some starter fluid and it fired right up.  Any help would be appreciated
Offline roundedline
Re: wiring
« Reply #1 on: May 08, 2006, 04:42:00 pm »
The power to the pumps should run through the valve.  Are the pumps coming on?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
