Author Topic: 86 K30 won't start or shift into gear  (Read 6339 times)
Offline leadlobber7
« on: September 01, 2018, 12:25:52 am »
I just changed my ignition switch on my 86 K30 454 TH400 4x4. I did drop the steering column by loosening the two bolts on the engine side of the firewall and also removed the 2  large bolts under the dash that upward support the steering column and the 4 bolts that bolt around the steering column. I got everything put back together and now my truck won't start and it won't go in gear.  I've no idea what's going on. I Any help would be appreciated. Thank you
Sent from my SM-G930V using Tapatalk
« Last Edit: September 01, 2018, 09:33:49 am by bd »
Re: 86 K30 won't start or shift into gear
« Reply #1 on: September 01, 2018, 09:50:05 am »
Leadlobber, your mailbox is full.  Delete some of your PMs if you wish to receive new messages.  Your struggle with posting new threads may be a temporary conflict with Tapatalk.
« Reply #2 on: September 01, 2018, 09:55:29 pm »
Does the starter crank?
