Author Topic: Difference in transmissions  (Read 5776 times)
Offline 86GMC4x4
« on: May 04, 2006, 09:39:00 pm »
I was wondering if there is a difference between TH700R4 transmissions in 2wd and 4x4 models or are they all the same?
Re: Difference in transmissions
« Reply #1 on: May 04, 2006, 10:55:00 pm »
Any 4x4 transmision has a shorter output shaft than a 4x2 trans. Unless you are talking old school / divoced transfer cases.
Offline roundedline
« Reply #2 on: May 08, 2006, 04:46:00 pm »
Reading into the question...  If you want to use a 2WD trans on a 4WD or vise versa, you have to pull either down and change the output shaft Blazin is talking about.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
