Author Topic: Cylinder getting Hot!!  (Read 3705 times)
Offline 78Hawk
« on: September 15, 2018, 10:08:24 pm »
I have a 78 C10 that I just had the engine rebuilt in. I have a 280 comp cam, Edelbrock intake, headers, MSD Ignition and distributor in a 454 big block.  I got the engine all back in truck and the number 7 cylinder is getting about 220 degrees. It’s starting to melt the paint before I turn it off.  What could be making this thing hot. It’s only hot on the driver side.
Offline roundhouse
« Reply #1 on: September 16, 2018, 09:20:02 am »
Running lean and not getting enough fuel as the other cylinders will make it run hot
You using a laser thermometer on the hear tube ?
I’d remove the valve covers and carefully check the push rod travel rocker arm travel
Make sure you haven’t wiped a cam lobe already or have a bent pushrod or broken rocker or pulled rocker stud
« Last Edit: September 16, 2018, 09:22:19 am by roundhouse »
