Author Topic: Distributor Wrench  (Read 5601 times)
Offline DouglasBeale
Distributor Wrench
« on: October 27, 2018, 07:41:56 am »
Do I need to order the distributor wrench to do the timing on my '86 350, or can I get in there with a regular wrench? I took all emissions stuff off so I have some extra room???
1986 Chevy K30
4WD Dually
Four Speed 117mm Transmission
NP205 transfer case
Quadrajet
Offline Rapid Roy
  • Euless, Texas
Re: Distributor Wrench
« Reply #1 on: October 27, 2018, 08:17:02 am »
I have been able to get to mine with a boxed end wrench but it is a very tight space. You can try to see if it will work for you then maybe need the dist wrench.
Mopar by Birth
Chevy by Choice
« Reply #2 on: October 27, 2018, 09:06:03 am »
Yeeeah..., I'm going to have to get out there. Darn cold today, wind, and rain. I don't even want to work on it anymore this season, but the snow's comming soon, and my wife doesn't complain about the expenditures, but she expects snow removal in return. I guess I got to cowboy up and drag myself out there.
« Last Edit: October 27, 2018, 10:18:39 am by bd »
1986 Chevy K30
4WD Dually
NP205 transfer case
Quadrajet
Offline Henry
« Reply #3 on: October 27, 2018, 10:52:40 am »
Hi Doug:
My 76 C-20 has practically nothing in the way of emissions equip and the dist bolt is still very hard to get to...I would go get the special wrench. It is worth it...especially when setting the timing. I bought a great one many years ago at Autozone that is a two-piece design that separates and you can put a ratchet on it as well...Snap-On brand, I recall.
Regards,
Henry
« Reply #4 on: October 27, 2018, 11:50:35 am »
« Reply #5 on: October 27, 2018, 01:41:12 pm »
Thanks guys. I'm going to go ahead and order one.
1986 Chevy K30
4WD Dually
NP205 transfer case
Quadrajet
Offline 86chevytrk
« Reply #6 on: October 27, 2018, 02:09:38 pm »
I bought a two piece one as well. I found it in the value tool bin at my local hardware store. I think I spent $9.99 for it. I does the job.
« Reply #7 on: October 27, 2018, 07:02:58 pm »
YEARS ago, we just took a long box end and heated it up...  Still have it somewhere
Offline Jason S
« Reply #8 on: October 27, 2018, 07:36:12 pm »
Along the same lines as Captkaos - Took a cheap box/open end wrench and cut the ends off the center section.  Then welded the ends to square tubing with an 'L' handle to yield a box end and an open end wrench.
Offline Da67goatman
  • Burban
« Reply #9 on: October 28, 2018, 10:50:55 am »
I use a stubby box end 9/16" and have been able to adjust all of mine through the years
<Pitcrew>
Offline Stewart G Griffin
« Reply #10 on: October 29, 2018, 04:30:23 pm »
A flex head wrench like this has been working for me:
https://www.homedepot.com/p/GearWrench-14-mm-Flex-Head-Combination-Ratcheting-Wrench-9914/202738068
A shorter 14mm, or 9/16th also could work.
It's still a pain, so i'm going to order the special wrench.
This is one area that i think ford, Buick and who ever else that put the distributor up front got it right.   On the other hand, you're not adjusting timing everyday.
