Author Topic: Barn door hinge pins  (Read 13281 times)
Offline Pheday
« on: November 01, 2018, 07:24:07 pm »
I’ve got a 1990 Suburban with barn doors. The barn doors are sagging pretty badly. They nearly touch at the top when closed and there is a big gap at the bottom. Are these hinge pins larger than your standard door hinge pins? I’m guessing they are but I’ve never actually taken one apart. I think my bushings are worn out and my pins may be bowed a little. Are the pins replaceable or do you have to scrounge a whole new hinge assembly?
Thanks for all the great info on this forum. Greg
1990 GMC Suburban 2500 SLE 4x4
Offline Pheday
Re: Barn door hinge pins
« Reply #1 on: November 18, 2018, 10:26:07 am »
Here is a sample pic of a removed barn door hinge pin and bushing. There are two bushings per pin. The pins about 2 11/16” in length. They are shorter than the regular door hinge pins.
Online bd
« Reply #2 on: November 18, 2018, 10:46:43 am »
The pin doesn't appear significantly worn.  Have you checked with a large inventory local hardware store or Amazon for the oilite bushings?  Don't forget to take samples with you.
Offline Pheday
« Reply #3 on: November 18, 2018, 12:06:16 pm »
Thanks BD. No I haven’t checked there yet, but I will. Those pins in the pics are from a donor set of hinges I got from a junkyard in Sacramento. I haven’t actually removed mine yet. I suspect my pins are more worn and the bushings are brittle. Thank you. Greg
Offline hatzie
« Reply #4 on: November 18, 2018, 01:43:25 pm »
It looks like the center pivot on the body side is broken and spinning freely between the door side pivots...  The bottom isn't looking particularly healthy either.
I don't have a Squarebody Suburban to compare so...
Could you take a picture of the hinge with the door swung open?
Offline Pheday
« Reply #5 on: November 21, 2018, 07:45:37 pm »
I took the hinges apart and replaced the bushings with these (Dorman Help! #38375) They are slightly shorter than the originals but they seem to work well. The new bushings removed about 1/4” of play. There is no more up and down play in the doors. My pins were straight. Now it looks like my passenger barn door may have been bent all along.
Offline Pheday
« Reply #6 on: November 21, 2018, 07:49:45 pm »
