Author Topic: Help with codes on a 12 bolt rear end  (Read 12202 times)
Offline CA76K10
« on: November 02, 2018, 09:22:15 pm »
Having trouble figuring out my rear axle. 12 bolt with the following markings...TBH(or TRH?) W217 2 on pass axle tube,  CN2 and H 2 2 on back driver side casting and finally GM58 and 3896839 N on the front of the casting. Any help is appreciated!
« Last Edit: November 02, 2018, 09:50:58 pm by CA76K10 »
Offline CA76K10
Re: Help with codes on a 12 bolt rear end
« Reply #1 on: November 02, 2018, 09:24:52 pm »
Having trouble with photos
« Last Edit: November 03, 2018, 01:26:32 am by CA76K10 »
Offline blazer74
« Reply #3 on: November 07, 2018, 01:44:04 pm »
KBH 3:73  open
W217 2      Warren Michigan Plant, 217 day of the year,  shift 2
Should be a date code on the center section web next to the vent tube starting with a letter for the month then 1 or 2 numbers for the day and the last number for the year. Should be a 6 for 76.
My 74 12B date code is A84. (January 8 1974)
CN2 or H 2 2 ?  Where is the H 2 2.
The GM59 and long 3896839 N number are just casting numbers for 12 bolt as far as I know.
« Last Edit: November 07, 2018, 01:49:52 pm by blazer74 »
