Author Topic: Leaking cab corners ?  (Read 3332 times)
Offline Payton1979Silverado350
« on: November 07, 2018, 07:07:44 am »
I have a 1979 K20 single cab(AC) and recently I’ve seen water dripping from right above the kik panels
I was wondering if anyone knew what I need to order or any suggestions on where the leak is coming from ?
Offline impco lpg
Re: Leaking cab corners ?
« Reply #1 on: November 08, 2018, 01:56:35 pm »
the leak will be coming from either, door cab seal / windscreen seal / bulk head wiper cowl.
mine was from under wiper cowl near heater fan.
remove glove box and kick panel. have someone with hose pipe spray water with you inside with a torch. you may have to remove dash top to see windscreen seal bottom.
« Last Edit: November 08, 2018, 02:19:55 pm by impco lpg »
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
« Reply #2 on: November 11, 2018, 02:40:38 pm »
Thank you
