Author Topic: 1981 k10 lift block questions  (Read 16278 times)
Offline Michael Pallos
« on: November 09, 2018, 11:03:10 am »
hello,
I have a 1981 chevy k10 swb. I was going to restore it but the engine caught on fire so now its mostly just used as a mud truck.  I would like to get it registered so I can drive it on back roads.  I was told that its safe to 2 in run blocks on the front end as long as I weld them to the axle to prevent alxe roll. I plan on adding ladder/traction bars also. What is the general opinion of this?
« Last Edit: November 09, 2018, 11:24:47 am by Michael Pallos »
Re: 1981 k10 lift block questions
« Reply #1 on: November 09, 2018, 03:36:22 pm »
its safe to use Zero Rate Add a Leaves. i wouldnt go anymore and you dont have to weld them
http://offroaddesign.com/catalog/Zero%20Rates.htm
Offline AZ4X4SQBDY
« Reply #2 on: November 10, 2018, 03:47:09 am »
Considering your intended use, I definitely would not.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Offline roundhouse
« Reply #3 on: November 12, 2018, 09:24:47 pm »
Blocks on the front are bad news
Don’t do it
« Reply #4 on: November 13, 2018, 08:24:09 am »
just to add the reason its safe to use the zero rates is because they bolt to your old leafs. so its pretty much like adding another leaf but it has no rating so the ride is still the same as before
