Engine/Drivetrain
1986 305 to 350 Vortec Swap
Topic: 1986 305 to 350 Vortec Swap (Read 6293 times)
Jeff86inMS
January 14, 2019, 02:51:28 pm »
Hello all,
I have a 1986 C10 stepside custom deluxe that originally came with a 305 V8. I'm getting ready to swap it for a 350 Vortec V8 with Carb. My question is, will the exhaust manifolds from the 305 swap over to the 350 Vortec? I know the intake manifold is different. Need to know about the exhaust ones though. Thanks!
Jeff
Re: 1986 305 to 350 Vortec Swap
January 14, 2019, 04:40:32 pm »
Yes but why not run headers? Exhaust manifolds will choke that thing right out
Jeff86inMS
January 14, 2019, 05:04:39 pm »
I will probably run headers later on, but trying to just stick to the items I have to have to get it installed.
Ronno6
Elder Student
January 14, 2019, 10:24:52 pm »
Exhaust manifolds should oughta bolt right up.
You can lead a man to water, but yoiu can't keep him from pissing in it.
JohnnyPopper
Old Goof
January 15, 2019, 12:46:27 pm »
Unless you need a manifold spreader tool.
I just had my 350 swapped out, and the mechanic showed me a tool to spread the the outer manifold ports away from the center ports.
Wish I had known about them the last time I changed the manifold gaskets, would have been a lot less &&%$#(!!!@#^%$#!!?
1973 C-20, 3+3 454 4BBL TH400 Water Injection
1980 C-10 under construction
zieg85
January 15, 2019, 12:57:23 pm »
The only caution would be the dipstick location clearing the manifolds.
75gmck25
1975 GMC K25 Camper Special, 350/TH350/NP203
January 16, 2019, 09:10:21 pm »
I had to use a manifold spreader tool to get one of the manifolds back on my new heads, so I actually read the directions. It worked very well. They recommended also using the tool before you remove the manifolds so that you can remove sideways pressure and get the bolts to come out without binding. The only local parts store that had the tool on hand was NAPA, but lots of places sold them online for $11-12.
Bruce
Last Edit: January 16, 2019, 09:12:19 pm by 75gmck25
JohnnyPopper
Old Goof
January 17, 2019, 06:26:25 pm »
It's the little things...
fitz
January 17, 2019, 06:52:55 pm »
Quote from: JohnnyPopper on January 17, 2019, 06:26:25 pm
1 more thing to look into is the distributor gear. You might need a different gear with the roller cam.
Engine/Drivetrain
