Author Topic: 1987  (Read 21917 times)
Offline lownuff
  • @lownuff
1987
« on: February 12, 2019, 03:51:16 pm »
Just found this forum so figured I'd post my put together.
This truck sort of fell into my lap. I wasn't really looking for a project but a guy at work needed to get rid of it and he even delivered it so here we are.
Trucks a 1987 Silverado package, all the fancy stuff. It's a long bed and the left side of the body has seen better days.
It's got a TBI 350 in it, it's supposed to run but haven't messed with yet. The trans is supposed to be bad but again haven't messed with it.
I bought a mexican short bed for it. Also grabbed a fender and a short bed tank.
As you can see it's gonna be quite a bit of work. I think the windshield sticker nails it.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #1 on: February 12, 2019, 03:52:15 pm »
And here's the bed. Not common, kinda ugly but it was cheap.
Offline JohnnyPopper
  • Old Goof
Re: 1987
« Reply #2 on: February 12, 2019, 04:05:41 pm »
Welcome from SoCal!
Looks like you're off to a good start.
I can't make out what the window sticker says...
1980 C-10 under construction
Offline lownuff
  • @lownuff
Re: 1987
« Reply #3 on: February 12, 2019, 04:26:03 pm »
Welcome from SoCal!
Thanks, it says will it make it haha
Offline lownuff
  • @lownuff
Re: 1987
« Reply #4 on: February 12, 2019, 04:26:55 pm »
So got the bed home and had to move it around.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #5 on: February 12, 2019, 04:29:23 pm »
Then I had to remove the old bed and man was this a pain in the ass. I then moved the truck into a better spot so I could work on it. Check out that sweet original two tone.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #6 on: February 12, 2019, 04:31:13 pm »
Found some interesting stuff after removing the bed.
Can't weld up an exhaust? No problem!
Also who needs drop shackles? Custom.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #7 on: February 12, 2019, 04:32:48 pm »
Grinded down some areas on the frame, welded on some stands to keep it in place, and cut it. No going back from here.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #8 on: February 13, 2019, 12:33:30 pm »
Picked up a new trans for it
Offline lownuff
  • @lownuff
Re: 1987
« Reply #9 on: February 13, 2019, 12:37:30 pm »
Welded up the frame, don't mind the welds.
Welded in a plate as well before I welded the inside.
Ground down the outside and then boom, short wheel base.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #10 on: February 13, 2019, 12:38:40 pm »
I couldn't even give the long bed away so I cut it up and made a bench out of it.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #11 on: February 13, 2019, 12:39:44 pm »
And that's where I am now. I got the tank brackets mounted but need to get a new fuel sending unit, I must've damaged the connector when I removed the tank or something.
Offline Rapid Roy
  • Euless, Texas
Re: 1987
« Reply #12 on: February 13, 2019, 01:31:41 pm »
Welcome to the site.
Mopar by Birth
Chevy by Choice
  • Old Goof
Re: 1987
« Reply #13 on: February 15, 2019, 02:37:30 pm »
Nice progress!
Keep them coming.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #14 on: February 18, 2019, 09:50:52 am »
Well, I got the bed on.
Then I wrapped up the wiring on the taillights, put fluid in the trans and decided to take it on a test drive.
I made it as far as my other driveway and the front u joint blew up.
Up next is replacing the front fender and start doing some bodywork.
