Author Topic: 1987  (Read 21916 times)
Offline cvbear
Re: 1987
« Reply #15 on: February 18, 2019, 07:48:55 pm »
Wecome to the forum.  This is a great group of people, you can get lots of help here.  I love the wheels on your truck!
Re: 1987
« Reply #16 on: February 19, 2019, 07:06:57 am »
Cool. The Mexican beds are neat
Offline lownuff
  • @lownuff
Re: 1987
« Reply #17 on: February 19, 2019, 08:56:17 am »
Thanks, they definitely need a good cleaning.
I'm still undecided on the bed honestly.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #18 on: February 25, 2019, 03:08:46 pm »
Well, the more I looked at the bed, the less I liked it. So I picked up a beat up stepside.
Slapped it on and I love it already.
Need to remove those homemade drop shackles, they're hitting one of the bed supports. Going to swap back to stock ones and do a flip kit.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #19 on: March 05, 2019, 03:07:49 pm »
It's about to get real junky before it gets pretty.
Pulled the front clip off last night.
Offline JohnnyPopper
  • Old Goof
Re: 1987
« Reply #20 on: March 05, 2019, 03:26:28 pm »
Looks like fun!!
What was the original color?
'78 had a couple of colors that went by 'Camel', there were dark and light versions, ones with metal flake were termed 'Poly"
1980 C-10 under construction
Offline lownuff
  • @lownuff
Re: 1987
« Reply #21 on: March 05, 2019, 04:13:30 pm »
Looks like fun!!
It sure is. Original color was two tone russet metallic and tan. You can see it on the back of the cab also. Someone must've really hated the color, because they swapped all the interior over to blue/gray.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #22 on: March 07, 2019, 01:50:17 pm »
Front clip is completely off and sold. Going to need a deep cleaning this weekend.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #23 on: March 15, 2019, 01:27:08 pm »
Well guys, this thread is about to take a pretty radical turn. What started as just a simple cleaning up and lowering has snowballed.
I was looking for a hood for my front clip swap and I ended up with a whole truck. Frame has been notched and is set up for a stock floor body drop...so I guess I'm putting together a bagged truck. Tune in for updates.
Now my backyard is a mess.
Tomorrow, I'm going to pick up the rest of the truck tomorrow. (Bed, bumpers etc)
Offline lownuff
  • @lownuff
Re: 1987
« Reply #24 on: March 18, 2019, 09:39:48 am »
Well picked up the extra bed, its not in good of shape as I hoped. I'll put it up for sale or maybe turn it into a bench.
Here's the frame I'm swapping everything to. Pancaked front crossmember, z'd and a big notch out back. Last bodydropped truck I had was a '97 Tacoma and it was traditional which meant zero room. This will be fun.
Cleaned up the backyard and moved the truck around, figured I'd stage it a little so I can start doing the swap.
Then I pulled the engine/trans out.
Next I want to pre-run all the brake lines and fuel lines in the frame before I set the engine in there.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #25 on: March 25, 2019, 01:19:31 pm »
Didn't get much done this weekend.
Got the cab off and the frame painted, also snaked in the rear brake line.  Also mocked up the rear axle, going to have to build the wishbone part of the 3 link.
« Last Edit: March 25, 2019, 01:36:03 pm by lownuff »
Offline lownuff
  • @lownuff
Re: 1987
« Reply #26 on: April 08, 2019, 09:53:26 am »
Got hit with a nasty cold so I've been down for a couple days. Ruined my weekend, but did manage to knock out another bench.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #27 on: April 16, 2019, 03:52:57 pm »
Well no updates, I'm trying to keep myself from getting burnt out and have reached a point where I'm trying to nut/bolt resto this and I can't do that to this truck. Did that on my last project and it took 3 years!
Did manage to take a couple hours on the bench though.
Offline lownuff
  • @lownuff
Re: 1987
« Reply #28 on: May 09, 2019, 12:50:29 pm »
No real updates, been using my weekends to run around collecting parts.
Bought this suburban
And here's what I bought the suburban for.
Pulled the engine/trans out. This was a huge pain.
Then I sold off what was left of the suburban.
I also built a ford bench somewhere in between there.
So now I've got the basic parts to start putting it together, need to do a lot of mock ups, but time to start moving forward now.
