Author Topic: How to: Adjusting the A/C-Heater Temperature Control Cable (All Years)  (Read 38441 times)
Adjusting the A/C-Heater Temperature Control Cable:
Referring to the diagram...
  • Remove the glove box door assembly.
  • Loosen (do not remove) the temperature control cable attachment screw (#241) located on top of the heater core case (VIEW B).
  • Make sure the temperature control cable (#240) is properly installed and retained at both ends (#242) with its spring ferrule fully seated in the yoke of the cable bracket (VIEW B).
  • Slide the temperature control knob on the dash control panel (#243) all the way to the COLD position and hold it there, forcing the cable firmly against the temperature door lever (#244), compressing the cable spring.
  • Tighten the temperature control cable attachment screw (#241).
  • Reinstall the glove box door assembly.
For a straightforward procedure on adjusting the A/C Mode - Blend Door Link, see the technical article:  How to: Adjusting the 1977-1987 (91) A/C Mode Door - Blend Door Link.
« Last Edit: March 21, 2022, 06:55:26 pm by bd »
