Members Rides
1987 R10...aka Belushi
4
5
Topic: 1987 R10...aka Belushi (Read 48372 times)
NLPed
Reply #15 on:
July 08, 2019, 05:46:08 pm »
I got the CPP springs and spindles off eBay since it’s free shipping and no tax. The flip kit just moves the rearend housing from under the leaf springs to on top of them. Pretty simple to do that part, and 5” of drop.
And I didn’t have to notch the frame. I did have to remove the factory rear bump stops though...that’s just a matter of removal of a few body rivets and they come off.
Last Edit: July 08, 2019, 05:47:52 pm by NLPed
JohnnyPopper
Old Goof
Re: 1987 R10...aka Belushi
Reply #16 on:
July 08, 2019, 08:22:17 pm »
Makes sense on the rear. I guess guys notch the frame when they want to slam it. More than I want to do.
Spindles I've seen vary in drop- what did you choose? It looks pretty flat.
Is there a difference if you just lop off a ring of existing springs?
1980 C-10 under construction
NLPed
Reply #17 on:
July 08, 2019, 08:42:38 pm »
I used the 2-1/2” CPP drop spindles and a 1” drop spring. If you’re going to cut a coil, you’d be well advised to cut new springs rather than old used ones. I’ve tried cutting used springs and even though I cut the exact same amount, they dropped different amounts. Doing the spring install more than once... SUX’s.
JohnnyPopper
Old Goof
Reply #18 on:
July 08, 2019, 08:49:59 pm »
Thanks brother, that's good advice!
NLPed
Reply #19 on:
July 08, 2019, 08:56:02 pm »
Quote from: JohnnyPopper on July 08, 2019, 08:49:59 pm
You’re welcome!!
NLPed
Reply #20 on:
July 08, 2019, 09:06:18 pm »
Oh, and since you asked... here’s a picture of my ‘77 that I sold this Spring. I kick myself for selling it.
I’d done some suspension upgrades and a full billet serpentine conversion with all new a/c parts/pieces.
Last Edit: July 09, 2019, 01:01:31 pm by NLPed
JohnnyPopper
Old Goof
Reply #21 on:
July 09, 2019, 12:46:12 pm »
Nice truck, got those same wheels for the '80.
Do they make a kit for serpentine replacement? and did you use a different compressor?
NLPed
Reply #22 on:
July 09, 2019, 01:06:14 pm »
I used the CVF Racing setup with a Sandin 508 compressor. It’s a nice setup, price is really good,but I did have to make custom lines for the compressor.
JohnnyPopper
Old Goof
Reply #23 on:
July 10, 2019, 04:47:14 pm »
Thanks again for the lead, I'll check them out.
I notice you are using the mechanical fan.
I had to change my water pump and decided it was time to go with an electric.
It feels like I picked up 15-20 Horsepower, no joke!
Even my wife says it's definitely more peppy.
I put the question out if anyone knows how much hp the fans use, no response. Yet...
NLPed
Reply #24 on:
July 11, 2019, 02:51:11 pm »
I installed a new front bumper air deflector last night. I just didn’t like it without it. In my opinion it Hides some of the ugly suspension and makes it look a little lower too.
NLPed
Reply #25 on:
July 12, 2019, 08:48:34 pm »
I finally got around to replacing the belts (4 D@mn belts) tonight. What a PITA!!! Whoever came up with the serpentine setup should get a Nobel prize!!! Only the p/s pump belt looked bad...but it’s the most inboard belt!!! So I replaced them all.
I’m also going to try my hand at replacing the headliner material tomorrow. Not real excited about doing this.
NLPed
Reply #26 on:
July 20, 2019, 03:51:19 pm »
I finally got around to removing & repairing the old headliner board... here’s before repairs
Then I cleaned and detailed all the oe trim, recovered the board and got it all back in today. Now the inside of this truck is dang near like new.
Sorry for the cell phone pics, but you get the jist.
DanMcG
Reply #27 on:
July 21, 2019, 02:54:48 am »
Nice looking truck!!
NLPed
Reply #28 on:
July 21, 2019, 10:14:31 am »
Thanks Dan!
NLPed
Reply #29 on:
July 25, 2019, 03:05:56 pm »
I decided the 15” wheels just did nothing for me, so I decided to put an old set of Boss 338’s I had stored on a shelf on it. Had to do some machine work on the HD rotors as these are 1st gen 338’s. But I’m much happier with the look now.
I also added a picture just to show the 383 can bake a Tire.
4
5
Members Rides
