Author Topic: 6 bolt Torque Converter  (Read 6057 times)
Offline JohnnyPopper
  • Old Goof
« on: July 12, 2019, 12:58:46 pm »
Hey Guys,
I bought a '88 C-30 and am replacing the th400. Got a used one (warrantied) from a yard I do a lot of business with, the tech pointed out that the T/C has 6 bolts.
Never seen one before, the original has 3.
Does anyone know the significance of why there are 6?
It came out of a '89 step van.
We opened up the pan and it was clean as a whistle.
Thanks for any guidance you can offer!
1980 C-10 under construction
Offline Stewart G Griffin
Re: 6 bolt Torque Converter
« Reply #1 on: July 13, 2019, 04:07:05 pm »
i've been seeing a few of these lately, because i have to do research on my own torque converter issues.....
i think 6-lugs are more heavier dutier/diesels.
What engine is in your c-30?
« Reply #2 on: July 13, 2019, 04:17:41 pm »
3 are SAE threads, 3 are Metric.  Choose which set of 3 you need
  • Old Goof
« Reply #3 on: July 14, 2019, 09:05:38 pm »
Wow, that's all the difference? You mean my new T/C isn't special after all?  :'(
When wrenching to get this pig out, I ran into bolts Sets, i.e. rear mount bolts,  that were clearly metric, the rest being SAE.
The T/C bolts were/are 15mm.
The only thing I could figure was that the BIG 3 were so $ conscious of cost per vehicle that they went with lower cost hardware where ever they could.
Please feel free to disabuse me if there is another reason!
  • Old Goof
« Reply #4 on: July 18, 2019, 03:04:03 pm »
Carl (Zeig) all the threads are the same. Now what?
« Reply #5 on: July 18, 2019, 03:33:59 pm »
Choose the 3 that line up with your flex plate
« Reply #6 on: July 18, 2019, 04:40:25 pm »
i know on my motor swap the flex plate on the motor there was only 3 holes for the th400. someone modified it to fit the 700r4 (made the holes closer to the edge). when i mounted it up to the 4l80e i had to bring the holes back in
  • Old Goof
« Reply #7 on: July 18, 2019, 05:06:11 pm »
There are 6 points on the flexplate. Used all 6.
So there is no indication that this is a heavier duty T/C?
Came out of a delivery van.
« Reply #8 on: July 18, 2019, 05:17:27 pm »
OK.  I learned something today.  I have 2 TH400's and the flexplate in my 85 has 6 holes.  I will have to check and see if mine is the same way.  I am missing a speedometer drive gear before I put the new transmission back in...
« Reply #9 on: July 18, 2019, 10:24:53 pm »
i didnt know about the differences till after i bolted the cummins in place and no bolt holes lined up. PIA to pull it back out and modify the flexplate to work with the 4l80e
« Reply #10 on: July 27, 2019, 05:37:13 am »
Yes, based  on my research it is heavier duty and/or installed  behind diesels.   C-40,50 trucks, motorhomes etc.
2) if you look at the  custom aftermarket converters that are put behind engines making 800+HP, they are 6 lugs.
 That's all i know for now.
« Last Edit: July 27, 2019, 05:43:24 am by Stewart G Griffin »
  • Old Goof
« Reply #11 on: July 27, 2019, 08:27:36 pm »
Wow Stuart, quite impressed! Thanks!
I admit I know very little about T/C's but wonder if this has a different 'stall' RPM?
I know that it can vary by design and application.
Hopefully this one isn't with a high RPM, however it is a C-30 with H/D rears suspension.
Any other Heavy Weight care to add to our knowledge base? TIA!
