Author Topic: Recommended Alternator amperes  (Read 3926 times)
Offline Chuck Step-a-side
« on: July 28, 2019, 12:34:44 pm »
I have a standard 85 amp alternator for my weekend driver. Should I get a higher amp alternator?  I have a 1984 Chevy Silverado Stepside w/ 350 V8 and 35 Trans. Thanks, Chuck
Offline JohnnyPopper
  • Old Goof
Re: Recommended Alternator amperes
« Reply #1 on: July 28, 2019, 05:15:34 pm »
Is it a stock setup?
Assuming you have a working ammeter, does it show the correct charging level?
Unless you are taxing the alternator with charging dual batteries, extra off road lighting, or have a camper with batteries, 85 is good.
I used to have the model number of the AC Delco alternator that put out something like 100+ amps, was going to use it to charge the batteries when I towed a fifth wheel.
But that was another life....
1980 C-10 under construction
« Reply #2 on: July 28, 2019, 07:17:46 pm »
Yes, it's a stock set up. I'll stick with the 85 amps. Thanks for the reply.
Offline 75gmck25
« Reply #3 on: July 30, 2019, 08:47:31 pm »
85 amp should be fine if you don't have any unusual accessories; however, the 93 amp Delco 12si V-belt version is also a direct replacement for your truck.  The next step up is the CS130, but its a newer design, and a little more complicated upgrade than the 12si.
Bruce
