Author Topic: 1973 to 1977 1/2 wheel hubs  (Read 8609 times)
Offline nickpc87
« on: July 30, 2019, 07:18:36 pm »
I have a 1976 k10 with one piece hub and rotor assembly. I cant find new hubs anywhere and my rotors are shot. Has anyone else dealt with this?
Offline Smokehouse
Re: 1973 to 1977 1/2 wheel hubs
« Reply #1 on: July 31, 2019, 12:52:23 pm »
you should be able to get those at any parts store that is all one piece while you are at it get new bearings and seals.
You are not that hot to be that bitchy.
Offline nickpc87
« Reply #2 on: July 31, 2019, 02:50:18 pm »
The hubs for 73 to 77 1/2 are not the same as late 77 to 87. The dimensions and bearings are different. I learned the hard way because i bought parts for an 86 k10 and they didnt fit right. Then i got the numbers off the frame and its a 77. 73 to the first half of 77 is different then the second half of 77 to 87.
I havent seen one piece rotor and hubs anywhere. I can get rotors for a 2 piece setup but ive only found one place that has hubs available  and theyre used and 200$ each. I cant be the only one to run into this problem
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: July 31, 2019, 07:48:24 pm »
Hmmmm...
consider changing your hubs to '78?
1980 C-10 under construction
Offline Smokehouse
« Reply #4 on: August 01, 2019, 12:49:51 pm »
i learned something today then. i guess you would just change it all out to late stuff then or just keep looking
Offline blazer74
« Reply #5 on: August 01, 2019, 11:09:14 pm »
Haven’t seen any early small bearing hubs out there either other than used.
Can’t say I even knew there were one piece 4x4 hubs out there.
Guess they were available as a replacement at some time.
My 74 has the original hubs and are 2 piece.
You’ll need the spindles and hubs from a the later larger bearing setup.
The inner bearing is slightly larger IIRC.
