Author Topic: INJECTOR CIRCUIT DIAGNOSIS CHART A-4 (TBI)  (Read 33806 times)
« on: October 09, 2019, 05:16:24 pm »
CHART A-4 - INJECTOR CIRCUIT DIAGNOSIS
Circuit Description :
This chart should only be used if diagnosis in CHART A-3 indicated an injector circuit problem. If both injector circuits fail to blink when tested, diagnose, one injector circuit at a time.
Test Description : Step numbers refer to step numbers on diagnostic chart.
This step tests for 12 volts to the injector. It will also determine if there is a short to voltage on the ECM side of the circuit.
This test checks for continuity to the ECM.
« Last Edit: April 12, 2024, 04:01:26 pm by VileZambonie »
