Author Topic: Bore out 350 or Swap 454  (Read 3275 times)
Offline Spool
« on: October 13, 2019, 08:38:23 pm »
73' C20
Getting way ahead of myself... As my truck has sat for three months with a knocking noise.
But, if I need to pull the engine, worst case, for cylinder work...
Is now the time to hone larger or swap for a 454 crate block?
Thoughts?
Prices?
Experiences?
« Last Edit: October 13, 2019, 08:44:52 pm by Spool »
Offline FlatBlack77
Re: Bore out 350 or Swap 454
« Reply #1 on: October 14, 2019, 09:30:17 am »
What transmission do you have?
What is your budget and power goals?
You cant swap 350sbc parts onto a 454bbc block. You would need to buy everything else to complete the 454. You would literally have to build the entire engine from the block.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: October 14, 2019, 12:56:50 pm »
Do you know how many miles are on the 350?
If miles are reasonably low, you might have a stuck lifter. I've heard some that sounded like bad rod bearings. Try some Rislone.
You won't know much until you tear down the motor and take measurements.
If you find a running 454 in good shape you will have the hardware/accessories required to do the swap.
1980 C-10 under construction
