Author Topic: Need 12V hot when ignition on only.  (Read 3486 times)
Offline Stewart G Griffin
« on: October 20, 2019, 03:14:50 pm »
On the fuse panel, is an "Accessory" slot, the same as an "Ignition" slot?
That is, are the "Accessory" slots only providing power when the key is in the "on" position ONLY----like an "Ignition" slot?
i'm running out of slots which is why i'm asking.
Offline MIKE S
  • Member
Re: Need 12V hot when ignition on only.
« Reply #1 on: October 20, 2019, 06:08:27 pm »
I’m pretty sure the difference between the two is ignition only comes on during cranking and run. Accessory would come on when the key is turned backwards from off and in run but not while cranking.
« Reply #2 on: October 20, 2019, 08:48:34 pm »
This ^^^^^.
