Author Topic: 14 Bolt Semi Float Pieces  (Read 9140 times)
Offline chili_mac11
« on: October 25, 2019, 02:26:36 pm »
Hey guys, total noob here. I was pulling the shafts from the carrier in order to remove my backing plates so that I could swap to discs. As I was pushing in the axle to remove the c-clip the pieces pictured dropped out. I know where they go but I don’t know how to get them back under the gears. Again, total noob, this is the first differential I’ve opened
Offline chili_mac11
Re: 14 Bolt Semi Float Pieces
« Reply #1 on: October 25, 2019, 03:14:53 pm »
Yeah I was quick to freak out. Remove the whole carrier, reassemble, put the pin back up through the middle to hold everything in place, re-install
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: October 25, 2019, 05:24:02 pm »
You're welcome.  ;)
Just kidding, glad you figured it out...
98 C2500 ext cab longbed
Offline chili_mac11
« Reply #3 on: October 26, 2019, 07:08:28 am »
Haha thanks Shifty. This is my first project so I get pretty nervous when I’m tearing into this stuff. I’ve probably got at least 500 pictures on my phone just to show where stuff goes when I finally put it all back together
Offline blazer74
« Reply #4 on: October 26, 2019, 05:00:43 pm »
Make sure you set your carrier preload correctly if you remove the carrier.
Offline chili_mac11
« Reply #5 on: October 26, 2019, 06:45:44 pm »
Thank you!! Would have never known what this was
