Author Topic: Transferring a 73 C body onto an 80 K frame  (Read 11600 times)
Offline BradRuiz 83
« on: November 10, 2019, 03:32:05 pm »
Will a 73 gmc 2 wheel drive body fit a 1980 k10 4x4 frame... anything helps  thanks Brad...
Offline BradRuiz 83
Re: Transferring a 73 C body onto an 80 K frame
« Reply #1 on: November 10, 2019, 03:38:25 pm »
Will a 73 longbed gmc body fit a 1980 k10 4x4 frame
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: November 10, 2019, 03:54:34 pm »
Are the wheel base's the same? Long Wheel Base vs Short Wheel Base.
Obviously if one is a short bed and the other is long bed you will have to do some extra work.
If it's close and you're not sure, measure from the front spindle to the rear axle center on the 2x
and the center of the hubs to the rear axle on the 4x. Do they match?
1980 C-10 under construction
Offline BradRuiz 83
« Reply #3 on: November 10, 2019, 03:57:45 pm »
Sorry... both trucks are longbed's
Offline BradRuiz 83
« Reply #4 on: November 10, 2019, 05:17:41 pm »
Did 1980 k10 4x4 come out with 10 bolt front axle...
Offline BradRuiz 83
« Reply #5 on: November 10, 2019, 06:10:29 pm »
Has anyone converted a 2 wheel drive to 4 wheel drive.  I have a 73 gmc 2 wheel drive long bed and just bought a 80 k10 longbed  4x4. I want to swap the 73 body on to the 80 frame....
« Reply #6 on: November 12, 2019, 08:12:56 am »
body swap will be the easiest/best option. the one thing you have to worry about is cutting a hole in the floorboard to make room for the transfer case shifter and either swapping center humps to the transfercase or install a 3" body lift
Offline BradRuiz 83
« Reply #7 on: November 12, 2019, 09:46:55 pm »
Thanks...
Offline 75gmck25
« Reply #8 on: November 13, 2019, 05:50:00 am »
In some years (like my '75) the 4WD hump in the floor is a separate bolt-in piece, but I think that at some point they just modified the cab floor itself to clear the transfer case. You can probably cut a hole in the floor of the '80 and just transfer the hump section over from the 4WD truck.
Bruce
