Author Topic: can I use this distributer?  (Read 7923 times)
Offline jetman373
« on: October 13, 2006, 02:00:00 am »
I have a 85 silverado,305/350,2wd,shortbox. Im replacing the 305 with a 327. I noticed there is a odd plug going into the distributer from the firewall.Is this a computerized distributer? Im using a edlebrock intake and a holley 600 carb. Im also loosing all of the smog stuff. Do I need a different distributer,or can I still use this one? Thanks!
Offline tlynde
Re: can I use this distributer?
« Reply #1 on: October 13, 2006, 08:09:00 am »
do you have a stock tach.?
if so it could be your tach wire. but I don't think it's computerized, somebody correct me if I'm wrong ;)
T
Offline jetman373
« Reply #2 on: October 13, 2006, 09:43:00 am »
There is no tach. The plug is a larger inline 4 wire that goes into the passenger side of the firewall.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: October 13, 2006, 12:05:00 pm »
If memory serves, the small block distributor should work on any chevy small block.  Throw that 327 in her and  reuse the distributor from the 305 and just plug the wires back up. Do not use an external coil!  The HEI distr in your 305 should have its coil inside the cap.
That would be a very simple changeover, just depends on the year of the 327 and ensuring you have enough accessory holes in the front of the heads for your brackets fo alt, pwr steer, etc.
I love the 327's!!!
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 10/13/06 11:10 am
Offline ChevyGuy
computer
« Reply #4 on: October 13, 2006, 01:12:00 pm »
If its like a 4 prong plug it goes to the computer located in the passenger side by the glove box. Gm tried a system that would monitor how things ran like the carb and dist. by a computer which i would bypass by finding a earlier model hei unit.
Offline jetman373
Re: computer
« Reply #5 on: October 13, 2006, 02:15:00 pm »
I was told today that it will run with the computer controled one ,but I'll eventually replace it with a older style.
Offline roundedline
Re: computer
« Reply #6 on: October 13, 2006, 04:12:00 pm »
It will work, but you need to bypass the computer control.  This is the infamous ESC that was used on the 305's.
Read this to eliminate it:
73-87.com/7387garage/driv...screpl.htm
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline jetman373
Re: computer
« Reply #7 on: October 13, 2006, 07:02:00 pm »
Thanks for the help! that explains it all.
Offline 1976Scottsdale
Re: computer
« Reply #8 on: October 14, 2006, 09:25:00 am »
You will like the 327.  Just grab an HEI unit from an old 350 in a bone yard or somethin'.  The just hook up the power wire after following the garage instructions.  E.S.C.(Electronic Spark Crap)
