Author Topic: Rear Drum Brake Tutorial?  (Read 5531 times)
Offline bzach
« on: April 29, 2020, 09:15:25 am »
Hey y'all, I've been lurking since last Feb when I got my '78 C10 SWB, now finally signed up for an account.  TLDR: is there a good rear drum brake job/adjustment tutorial somewhere?
Took my bucket to a shop to get a posi and 3.73s installed, and they did the rear brakes as well.  Something seems a bit off, and the driver's side adjuster for sure needs to be replaced so while I'm in there I want to go through everything.  This being my first set of drum brakes, I have no idea how things come apart.  Could someone point me to a good thread that details disassembly and adjustment?  Thanks in advance!
Here's some more info about Truck Showalter:
400 small block with a mystery cam (PO didn't have much info about it)
TH350 soon to be a 700r4, as soon as I can get the thing rebuilt
Lowered 2" all around
Slowly working through cleaning her up: replaced the gas tank, reupholstered the bench with new foam, new AVS2 carb, cleaned and polished valve covers/intake, and many more weekend items.  She almost leaks no oil now!
Re: Rear Drum Brake Tutorial?
« Reply #1 on: May 02, 2020, 12:46:19 pm »
« Reply #2 on: May 03, 2020, 07:04:51 am »
Measure your shoes when you take the drum off so that you know which ones to get parts for. Order the good hardware kit that comes with almost everything. I will be doing a video on drum brakes next week and will share it when I do.
Offline bzach
« Reply #3 on: May 03, 2020, 10:08:33 am »
Thanks for the info and replies.  That exploded view especially is very useful.  I did measure my shoes before this so I managed to order the correct parts for once.
Took care of everything yesterday, replaced the broken self adjustment assembly on the drivers side, and found a leaking wheel cylinder on the passenger side.  Got a new cylinder in, cleaned it all up, and put everything back together with new drums; hopefully that solves my locking up issue.  Overall it actually wasn't as bad as people make it seem.  I also found a great  YouTube video called "How to replace drum brakes, wheel cylinders and front pads GM" that helped out a lot.
