Author Topic: Somewhat Urgent Question about Interchangability  (Read 10067 times)
Offline JohnnyPopper
  • Old Goof
« on: November 17, 2020, 02:04:46 pm »
I'm having a 3.42 installed to replace a 3.73 diff. There is a stock posi-traction on the 3.73.
With help from this forum, I discovered it will drop my highway RPM from 3000 to 24-2500. That's where the torque peaks as well.
I don't off road, it's my daily.
Just got a call from the shop, they said the posi will not work now, and that they need to install a standard diff.
Yesterday when I was there, there was no mention of a problem.
Q: are these interchangeable? Or are they trying to sell my posi from under me? In any case, I told them to box up my posi in case I want to restore it.
Any help would be appreciated.  :D
1980 C-10 under construction
Re: Somewhat Urgent Question about Interchangability
« Reply #1 on: November 17, 2020, 02:13:16 pm »
Which year/model truck and model axle?
The differential deck height for an 8.5" 10-bolt allows 2.73:1 and greater gear ratios to employ the same case.  So ask for a specific reason that your LSD won't work.  Without more information, I agree.  It sounds suspect.
« Last Edit: November 17, 2020, 02:32:04 pm by bd »
  • Old Goof
« Reply #2 on: November 17, 2020, 02:30:00 pm »
'78 12 bolt
« Reply #3 on: November 17, 2020, 02:43:17 pm »
The truck 12-bolt uses three (3) different cases, dependent on gear ratio range:  2.73:1 down, 2.76:1 - 3.42:1, and 3.73:1 up.  The deck heights between the cases for the gears you have are different.  The 3.42:1 gear requires a differential case that moves the ring gear further from the pinion gear centerline.
  • Old Goof
« Reply #4 on: November 17, 2020, 03:20:18 pm »
So it is legit. Thanks bd!
« Reply #5 on: November 17, 2020, 05:11:15 pm »
You are changing the rear ratio to 3.42:1 - from 3.73:1 posi? What about the front? Curious why you downgraded yourself?
  • Old Goof
« Reply #6 on: November 17, 2020, 07:56:31 pm »
Originally the shop didn't indicate that I would lose the posi... not real happy about that.
I don't off road this truck, daily driver. This will put highway speed right at 2500 RPM.
Front is disconnected for now.
« Reply #7 on: November 18, 2020, 04:50:45 pm »
 :o
  • Old Goof
« Reply #8 on: November 19, 2020, 07:52:28 pm »
I'm keeping the stock parts, will probably have the front converted or restore the rear end at some point in time.
Ultimately OD will be the solution.
Offline ehjorten
« Reply #9 on: November 20, 2020, 01:56:44 pm »
If you had been going from 3.42 to 3.73, you could have kept your Posi and used a "thick" 3.73 ring gear set, but you're doing the opposite.
-Erik-
